11-18-2013, 07:30 PM | #1 |
Drives: 2012 CHEVROLET CAMARO ZL1 (BLACK) Join Date: Aug 2011
ZL1 SUPERCHARGER
Besides putting my car on a Dyno, Are there any other ways to tell if my supercharger is really working? These are the performance mods I've done so far, (FULL LPE 650 HP ENGINE KIT, KOOKS 1 7/8” LONG TUBE HEADERS WITH KOOKS CONNECTION PIPE WITH CATALYTIC CONVERTERS HOOKED UP TO NOWEEDS LS3 EXHAUST DIVERTERS, REVISED INTERCOOLER PUMP WITH KDI HEAT EXCHANGER.)
Fuel Injections promised me up to 15LB boost, my boost gauge never goes past zero. When do I get to see the results of all these mods? I'm not really feeling it. How can I tell if my supercharger is really putting out any power? Last edited by jydenwr; 11-18-2013 at 07:43 PM. |
11-18-2013, 07:44 PM | #2 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
Look at the four little gauges under your radio. The top, right side one in particular. Your supercharger is doing its thing any time the little needle goes past the zero indicator. lol
11-18-2013, 07:48 PM | #3 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
It's the bottom right gauge, but yes.
11-18-2013, 07:56 PM | #4 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Does the gauge move at all?
When cruising, the gauge is normally all the way to the left. As you press on the gas, the needle should move towards zero or the middle of the gauge. Now plant the loud pedal to the floor and hang on. Boost doesn't normally start in till over 3000rpm give or take at which time you should feel the get-up-and-go-like-hell as well as see the boost gauge head to the right side of the gauge indicating how much boost you're making. |
11-18-2013, 07:57 PM | #5 |
Car Lover By Nature
11-18-2013, 08:15 PM | #6 |
Drives: Camaro's, always have, always will. Join Date: Oct 2010
..yes it was...LOL. the gauge does move when the boost kicks in, but....your eyes need to be on the road to wheel the car at WOT and not look at the gauge. At least thats the way it's supposed to go.
In Scott We Trust...all others must show proof.
11-18-2013, 08:21 PM | #7 |
If you read my post in its entirety, you would have noticed that I actually mentioned in there that the boost gauge has never moved past zero. I went up almost 5000rpm on 1st gear while a friend of mine kept an eye on it. it went up to zero and that was it.
11-18-2013, 08:23 PM | #8 | |
For your information, I've never really noticed it until my friend mentioned it to me. And you are absolutely right. My eyes need to be on the road when driving. And you should put in an application for a position with U.S. DOT. The Obama administration could really use a guy like you right now. |
11-18-2013, 08:30 PM | #9 |
Drives: 2010 2SS/RS M6 Join Date: Aug 2013
You say 5000 rpm in first.. Just making sure the car was moving right?
You won't see any boost revving it at idle. |
11-18-2013, 08:35 PM | #10 | |
Ok. the complete scenario! My friend and I went for a cruise around town. He mentioned that the Boost gauge wasn't moving past zero. I peeled off topping 5000 on first. Still nothing. He thought maybe one of the hoses wasn't attached properly. We removed the engine cover and checked all the hoses, but everything looks fine, so idk. |
11-18-2013, 09:03 PM | #11 |
Drives: 2014 ZL1m6 red hot #569 Join Date: Dec 2009
make sure the belt is on
11-18-2013, 09:18 PM | #12 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Make sure the bypass valve isn't stuck open! A scan tool will show if you really are in boost. Faulty gauge possible, faulty wiring, something unplugged, or you really aren't in boost.
Bryan 2018 ZL1 M6
11-18-2013, 09:26 PM | #13 |
All in all, putting it on a dyno is the easiest way to verify your power. I know you were looking for another way, but when it comes right down to it, a dyno run is best.
11-18-2013, 09:27 PM | #14 |
Did you do these steps?
Bryan 2018 ZL1 M6
