04-26-2020, 03:34 PM | #1 |
Drives: 2011 Chevy Camaro LS Join Date: May 2016
Bad Pump? Loud noise when revving and turning wheel
Every time I rev my car or/and turning the wheel I hear a whining noise.
How easy it is to change the power steering pump? Or if it’s not that what do you think it might be? |
04-26-2020, 05:20 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Checked the fluid level?
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
05-01-2020, 09:59 AM | #3 |
Drives: 2014 camaro SS Join Date: Jan 2019
I thought it was an electric rack, no belt driven pump or fluid to check. revving the engine wouldn't make the steering whine
05-01-2020, 10:01 AM | #4 |
check your drive belt, the amps the rack uses will strain the alternator belt and make it squeal as well as revving the engine
05-01-2020, 05:30 PM | #5 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Electric power steering wasn't initiated in use until the ZL1. My 2012 still has hydralic power steering.
05-01-2020, 05:47 PM | #6 |
Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
has hydraulic steering
check fluid level with engine off |
05-01-2020, 11:07 PM | #7 | |
The alignment is necessary? Shouldn’t the alignment be included? |
05-01-2020, 11:47 PM | #8 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Where are you in Texas? If near DFW, I can recommend an honest shop.
05-02-2020, 05:20 AM | #9 |
05-02-2020, 05:33 AM | #10 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
$850 does not sound expensive for a rack replacement. Yes an assignment is necessary of course you are going to pay for it why would they work for free? I mean they can add the alignment price into the quote if you'd like to feel like you are getting it for free, but most shops have a set menu price for an alignment that's why it's separated in the quote.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
05-02-2020, 09:34 AM | #11 |
05-03-2020, 08:39 AM | #12 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
DO you have a glazed power steering belt first things first...maybe some spray for belt squeal could help, first things first..or lightly sanding the sides of a v belt works also, then replace the belt, even getting a suction bulb and replacing the fluid in the reservoir...… Start with first things first....Good Luck! I have not had one of the v-6 only a couple v-8s but belts get old....
05-05-2020, 02:22 PM | #13 | |
