Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 10-16-2020, 04:44 PM   #1
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
GForce driveshaft question
Anyone that has a @GFORCE1320 driveshaft, can you tell me if your u-joint yokes are out of phase?
I bought a used driveshaft that was supposedly rebalanced but it vibrates horribly. After some research, it looks like it may have been assembled incorrectly when they replaced the boot over the slider.
Pinion angle seems to measure ok using the Tremec app and I still need to check for runout, but I have a feeling it just needs to go to a local driveshaft shop.
Sent from my Pixel XL using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
larry_g is offline   Reply With Quote
Old 10-17-2020, 10:20 AM   #2
larry_g
larry_g's Avatar
Saturday bump, anyone with experience on this?
Old 10-17-2020, 01:31 PM   #3
larry_g
larry_g's Avatar
So I'm just going to take it to a local driveshaft shop Monday but I thought I'd share what I'm dealing with in case anyone else has this issue.
I bought the driveshaft used, it had the boot replaced and had been rebalanced. I saw the reference marks they used and never even thought to check if the ends line up.
If you look at the first picture, you can see that the u-joint yokes are not aligned with each other (out of phase). In the second picture, you can see how far off the reference lines are when the yokes are aligned.
Old 10-19-2020, 11:26 AM   #4
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
Not sure if this helps much but....GM intentionally off-clocked the yokes on old school driveshafts to improve NVH.
This is a good question to ask your driveshaft shop.
Stingr69 is offline   Reply With Quote
Old 10-19-2020, 11:55 AM   #5
larry_g
larry_g's Avatar
So the local place I dropped it off at said they always align the yokes. I was able to call GForce and they said they experimented with out of phase to match GM back in the 90's but not for mine.
Sometimes used parts are a real find (like my Whipple) and sometimes not so much.
Old 11-12-2020, 07:31 AM   #6
Need$f/parts
Drives: 2011 Camaro II SS Supercharged
What was the outcome? I’m fighting a similar issue and I’m curious what you discovered?
Need$f/parts is offline   Reply With Quote
Old 11-12-2020, 07:50 AM   #7
larry_g
larry_g's Avatar
The shop I took it to checked the balance after I put the yokes in phase and told me it was fine, didn't even charge me for checking it. While I was at it, I replaced the front driveshaft adapter because the previous owner had damaged some threads and I wanted to eliminate any potential issues. I also rechecked the pinion angle with the exhaust out of the way and it was spot on.
I'm not hearing or feeling the driveshaft vibration I was before, but my motor, trans, and cradle mounts pass so much noise to the cabin that I can't tell if it's perfect.
Overall, I'm pleased with it, but I probably would have been better off just buying a new one.
Old 11-12-2020, 08:21 AM   #8
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Intentional out of phase shafts are made that way almost always because of compound angles. That is, where say the trans and diff not only have a upward or downward angle, there is a side to side offset as well. Not much of either of those exist in our Camaros that I'm aware of.
Our company produced the OE Polaris drivelines and purposely built them out of phase because of crazy offset angles. Polaris' engineers came up with this configuration.
I can say this, almost without exception, when those shafts ended up at a driveline shop for repair, those shops put them back in phase and cured some tortional vibrations. Class 8 Volvo trucks used to have a design where the drivelines were out of phase but it's pretty rare and given the 'non uniform motion' of a standard u-joint, keeping them in phase is generally best - provided the trans and diff angles are near parallel.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 11-12-2020, 09:56 AM   #9
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I have a Drive Shaft Shop 1pc and it’s uses a CV joint on o send an regular yoke style on the other and don’t have or had any issues with it.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 06-25-2022, 10:17 AM   #10
LS3SSSuperSport
Drives: 2010 Camaro SS
I have DSS drive shaft I bought used, took to a shop to get it balanced, however they said would it would be hard due the design. It has slight vibration over 75mph, and I dont like it. What's weird is the shifter and trany feels smooth but you still feel it un your butt. Below 60mph it's fine. I've heard that 1 piece DDS shafts suck above 120mph and yes they do.
How fast have gone in the Camaro above 120??
LS3SSSuperSport is offline   Reply With Quote
Old 06-25-2022, 06:33 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have the DSS 1 pc for the last year or so and have been 140 with no issues, and several 7500 rpm pulls on the dyno.. Also when I'm doing WOT pulls the trans shifts at 7200..
1JEWLDSSRS is offline   Reply With Quote
