Old 03-09-2018, 08:17 AM   #1
Bill_76
Drives: Camaro ZL1 2018
Afe vs BMR vs Eibach vs Phastek Springs vs oem 2018
Hi all,
I have a 2018 ZL1A10, it has the lower springa from factory, but I want to lower it a little more, I saw a few pictures and seems that the aftermarket springs do not reduce the height more than the oem 2018. Anyone made a comparation or have photos, I do not want to buy them and then do not see any change.
Thank you!!!
Bill_76 is offline   Reply With Quote
Old 03-09-2018, 08:25 AM   #2
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
Eibach springs, very noticeable drop on my ZL1. Pics really don't do it justice...in person it is obviously less gap.
Car drives generally the same, slightly firmer.
Zero issues, install took about 3 hours.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 03-09-2018, 10:34 AM   #3
c6vette
Drives: 2017 ZL1
My 2017 looks exactly the same height as your car sakudog and the springs are factory. This is why I have help off on buying any brand of springs because the lowering claims seem to vary wildly.
c6vette is offline   Reply With Quote
Old 03-09-2018, 11:06 AM   #4
neenja_jenkins
neenja_jenkins's Avatar
Drives: 2017 Camaro ZL1
I dunno, his car looks lower than a standard ZL1 to me, quite a bit lower than even the updated springs.
I've held off as well though for the same reasons. IMO a less than 1 inch drop isn't worth it, and I'm a bit disappointed that's really our only option.
I'm considering just going with a set of coilovers, but I'm not sure it's worth losing MRC.
neenja_jenkins is offline   Reply With Quote
Old 03-09-2018, 11:40 AM   #5
Bill_76
thanks for the photos, can you measure from the floor to fender? I have 27.5 inches nowadays, just to compare. Thks!!!!
Old 03-09-2018, 12:28 PM   #6
c6vette
Drives: 2017 ZL1
mine is 27.5 front and 27 7/8 rear on stock springs
Old 03-09-2018, 01:25 PM   #7
MOSAIC BLACK 1LE
Drives: Mosaic Black ZL1 M6
I’m in the same boat. Wished they offered more lowering specially the fronts.
MOSAIC BLACK 1LE is offline   Reply With Quote
Old 03-09-2018, 01:56 PM   #8
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Interesting topic. I have an '18 on the way and I'm thinking BMR springs right off the bat, but they probably will only get .5" in of drop. I know that Phastek's package supposedly drops it pretty good but still probably under 1" on MRC cars.
Old 03-09-2018, 03:35 PM   #9
Bill_76
I think the problem is that the development was made pbased on 2017 model spring, so then with 2018 oem springs there is no difference, I sent an email to eibach and h&r saying please revise them, but nobody answer...
Old 03-09-2018, 04:18 PM   #10
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
From what ive seen none of the common spring options go much lower, if any, than a ZL1 with the updated springs.
mdmoore23 is offline   Reply With Quote
Old 03-10-2018, 07:11 AM   #11
Sakudog
Sakudog's Avatar
"Looks" lower, in the picture on the Internet, but it isn't and in person, there isn't a question the car looks much better on Eibsch Springs.
Let's do this, take a picture of a tape measurer at the top of your fender, up through the center of the wheel. FR, RR, FR, RL and let's see what you have in ride height. Maybe your car is as low as mine stock, but I doubt it.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 03-10-2018, 07:41 AM   #12
Sakudog
Sakudog's Avatar
I put the car on the lift yesterday to adjust the Borla Exhaust, so the suspension is still compressing, I'll update the measurements next week after a few hundred miles.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Old 03-10-2018, 12:58 PM   #13
c6vette
Drives: 2017 ZL1
First pic is front, second is rear. Looks like almost an inch lower in the rear but barely 1/2" in the front. I'm going to continue to hold off until there is a better option.
Edit: no idea why they are sideways...
Old 03-10-2018, 01:55 PM   #14
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
Mine is a '17 and definitely lower on Eibach springs. Looks perfect to me and I wouldn't want it any lower.
