Old 03-06-2016, 01:39 PM   #1
roorback
Drives: V8 permagrin
Towelless drying recs
What is the best non-towel drying machine for the buck? I'm looking at the DP turbo dryer. I tried to search but I'm not sure what they are technically called. Thanks for any recs.
roorback is offline   Reply With Quote
Old 03-06-2016, 01:43 PM   #2
EWade
EWade's Avatar
Drives: 2015 Camaro LS
There is a air dryer that motorcycle owners have used, called the Master Blaster, it blows warm filtered air through the hose to disperse water on any surface. Been tempted to get one since I own to bikes, but I do dry all my vehicles with an absorber.
15 LS in Blue Velvet
EWade is offline   Reply With Quote
Old 03-06-2016, 02:58 PM   #3
bigwayne3000
Drives: 2011 Camaro LS
I just use a $30 or $40 electric leaf blower I got from Home Depot. Works fine and if I have any spots I just follow up with Adams detail spray and mf towel.
bigwayne3000 is offline   Reply With Quote
Old 03-06-2016, 04:01 PM   #4
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
I use my motorized back pack leaf blower. Moves a lot of air. Dry in no time.
Quicksilver-SS is offline   Reply With Quote
Old 03-06-2016, 04:05 PM   #5
ghosted
BCS Auto
ghosted's Avatar
Drives: 2015 Camaro 1LS
I use an Adam's Microfiber Drying Towel ever since I got one in a mystery box. I've been thinking about picking up one of their Master Blaster Revolutions or the Sidekick model...but the price just holds me back since I have other car mods on the list.
http://adamspolishes.com/adam-s-grea...ing-towel.html
BCS Auto on Facebook - - - Follow me on Instagram @datv6tho & @officialbcsauto
ghosted is offline   Reply With Quote
Old 03-06-2016, 07:22 PM   #6
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
A pooling rinse. Gets 80-90% of the water off the car, leaving very little to dry.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 03-07-2016, 04:42 AM   #7
BRZN
BRZN's Avatar
Drives: 2012 1LT
The pooling rinse will work as long as the vehicle has a good coat of wax on it.
I use the Metro Master Blaster for touch-less drying. Warm filtered air being pushed at either 4 or 8 horsepower!
A leaf blower will work, an electric leaf blower. Problem is, the air it's blowing isn't filtered and can blow contaminants onto the finish. If you would follow up with a towel wipe down anywhere you could start to induce marring to the finish.
BRZN is offline   Reply With Quote
Old 03-07-2016, 04:41 PM   #8
rock1962
rock1962's Avatar
Drives: 2018 Camaro SS
Electric leaf blower. Pat dry any leftover water.
rock1962 is offline   Reply With Quote
Old 03-07-2016, 04:48 PM   #9
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I use a Metro Master Blaster!
I used to use a leaf blower but the noise was too much for my ears, shoulder would hurt too, The Blaster is really pricy but I feel its worth it.
-bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 03-07-2016, 04:49 PM   #10
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Bingo!!
http://adamspolishes.com/shop/access...evolution.html
Adam's Polishes is offline   Reply With Quote
Old 03-07-2016, 05:00 PM   #11
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
The sidekick is great for blowing water out of seams and light bezels - for that it's worth the money, not to mention that it's quieter and less cumbersome than a leaf blower. But it would take a while to dry a whole car with one. You'd probably want something a little bigger for that.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 03-07-2016, 06:20 PM   #12
Joe M 2012 2SS
Drives: 2012 2SS
Not true.
A car with no wax will still pool rinse and remove water, it will just sheet off slower.
Sealants and coatings, like wax, can also cause faster sheeting as well.
Duragloss 901 car shampoo increases sheeting action.
Some waxes/sealants/coatings while sheeting faster, will actually leave more water on the car then if it was just polished and had no protection after a pooling rinse.
For the OP here is the pooling rinse technique, start from the top and work your way down, very little water will be left to dry.
I use 1 spray of detail spray per panel after pooling, to further speed up the process. The Microfiber Madness Dry Me Crazy towel will easily take care of the rest of the water without causing any marring to the paint.
Old 03-07-2016, 06:43 PM   #13
BRZN
BRZN's Avatar
Drives: 2012 1LT
Originally Posted by Joe M 2012 2SS View Post
Not true.
Hmm, that's odd, 'cause cars I do, won't pool without wax or sealant on them. Without a coating the water lays flat on the surface. Something has to break the surface tension to allow the water to roll off once pooled up.
Old 03-07-2016, 06:52 PM   #14
BUSHMASTER
BUSHMASTER's Avatar
Drives: 2013 VR 2SS RS 1LE NPP
Double k dryer... Made for pet grooming but has more than enough power to blow water off any car. It bows almost as much air as the master blaster using simple 110v plug..master blaster on the other hand requires at least 10 amps In order to get up to full power. The body of the double k challenge air product line is made out of a thick durable plastic that won't rust and has 2 motors. You can drop it from 10 feet (look for the you tube video) and it keeps on working. Learned about these dryers from my dog groomer and it works great!
BUSHMASTER is offline   Reply With Quote
