12-09-2023, 03:58 PM | #15 |
Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
I was messaging Mike on FBM and he is going to get a hold of me when they release the pump in March/April 24’.
12-09-2023, 04:07 PM | #16 |
Yeah I’m definitely interested in details as soon as we can get them. I’m now torn between this and the upcoming DSX port option.
12-09-2023, 04:31 PM | #17 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Whoever comes out first with more flow than the LPE, I'm in.
I wonder if they will release any leading edge angle data. |
12-10-2023, 05:14 PM | #18 |
Drives: 98 Camaro Join Date: Apr 2022
https://www.camaro6.com/forums/showt...&highlight=Jms
Referencing this thread, I hope the new pump has better results than this. Only a 15% increase in E content. That’s pretty sad lol |
12-10-2023, 06:15 PM | #19 | |
It sounds like this new pump can move even more volume AND carry it at higher pressures. Sounds awesome, frankly.
12-10-2023, 09:07 PM | #20 |
Something must have been off with his then cause he said he had the pump and injectors. Guessing +30’s % injectors
Either way I have my fingers crossed that this pump works good. I have lt4 everything + jms and I’m trying to hit 9’s. It’s either meth or this pump and I’d rather have the pump |
12-10-2023, 09:38 PM | #21 | |
Really looking forward to more details on this new pump.
12-11-2023, 09:00 AM | #22 |
Yeah I agree. There are definitely gains but it's not a lot for the cost. Back when the LPE pump was 1500.00 it made more sense. +30/LPE HPFP is worth about +80whp of additional fuel headroom on a stock cam car. I can get LT1's to around 700whp on E60 and LT4's to around 720whp with that fuel system. You definitely wouldn't get there with LT4 fueling on E60.
2016 NFG 1SS A8
12-11-2023, 09:38 AM | #23 |
Drives: 2015 Camaro ZL1 Join Date: Oct 2020
We're still in the testing phase. Everything so far has been VERY promising.
We made over 1,300hp with turbos and full E85 on the engine dyno. We made 1520hp on C16 with <100° pump angle when the inercoolers would no longer keep up. LT4 injectors will operate at 3,600psi. We have been doing it for years. +30% injectors are stable to roughly 3,200psi and +65% are stable at 2,700psi. Cost will be less than the LPE but do not expect it to be 50% less. |
12-11-2023, 11:26 AM | #24 | |
12-11-2023, 11:31 AM | #25 | |
I want to say the final number was 1320hp on full E85 and we were just clipping 130° of pump angle at the top. |
12-11-2023, 11:35 AM | #26 |
Ok, great. That’s an important distinction as holding that high fuel volume at 2700 psi is impressive. If you have to drop the pump to 2200 psi then your injector output scales down. While it’s not a linear drop, it’s still an issue so I’m glad to hear the pressure stays up. It doesn’t look like we’ll see any injectors bigger than +65 anytime soon (unless you know something there haha).
12-11-2023, 12:42 PM | #27 |
That's 1320hp at the flywheel correct? I believe this was done on an engine dyno. Originally on Facebook I thought it was WHP.
12-11-2023, 01:51 PM | #28 |
Drives: 2016 Camaro SS Join Date: Oct 2021
This still looks to be a very expensive path compared to current port injection systems not to mention the upcoming DSX.
What would be the benefit to going this route vs. port injection?
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
