Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 11-20-2012, 08:24 AM   #1
Blue70SS
Blue70SS's Avatar
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry
Who has the Torq Supercharger Innercooler tank with Drag Cap Installed?
Has anyone used one of these or another brand that could provide feedback? I'm Mostly curious how well it worked at keeping the Air Intake Temps down when packed with ice for 1/4 mile use, and also how well it worked for overall street use. I already have the Torq dual pass Heat Exchanger with fans and am going to add the Torq ZL1 Innercooler pump upgrade. I have a Maggie running 14 lbs at Mile-Hi elevation, but other roots style superchargers before/after results would definitely apply.
I don't trailer and need room to load slicks in the back seat & trunk, plus do club road trips & Cfest with the slicks/luggage/tools - so above battery in trunk is out. Only other option is a custom fabricated tank that would mount below the trunk by the battery and ditch the air pump.
http://www.gettorq.com/store/chevrol...tank-torq.html
LPE 650+,IOM Pearl White Rallys
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC
NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc
Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions
DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit
RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS
Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop
StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock
PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit
LPE Brotherhood
Blue70SS is offline   Reply With Quote
Old 11-20-2012, 08:37 AM   #2
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Cant give you anything positive for the tank since it would not fit right with my setup and I wasnt to happy about deluting my coolant by adding ice so I returned it for torqs dual pass HE with fans. That works like posted and really keeps temps down.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 11-20-2012, 09:13 AM   #3
Blue70SS
Blue70SS's Avatar
I know there was issues with it not working on all superchargers and some issues with hitting the hood on some people. Torq has redesigned it and is close to getting the new units out. It's supposed to work with all the popular superchargers. The dual pass with fans definitely helped me out - but I still have to battle AITs at the track since I'm spinning the Maggie so fast and tuning for 91 octane.
Also might step up the speed by overdriving the harmonic balancer - currently 3% underdrive, +3% and +6% shells available. Controling heat will definitely have to be addressed if I persue more boost.
LPE Brotherhood
Old 11-20-2012, 10:43 AM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
We run ice in our 7 second drag radial car, keeps the temps down. I don't see a 160 thermostat in your list of mods, I would do one. Heat is your enemy.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 11-20-2012, 11:05 AM   #5
SC2150
Drives: 2012 Camaro RS, RX supercharged
We use those on the big HP builds and it is a great help....but if you want to really address it look into our RX Super Chiller. Not a hard install.....adds very little weight, and will keep IAT's far lower than any ambient air temp solution can. Were seeing temps in the 30's and 40's now it is in the 70's here.
SC2150 is offline   Reply With Quote
Old 11-20-2012, 06:32 PM   #6
Blue70SS
Blue70SS's Avatar
160 degree thermostat is in all the LPE builds and I agree is a must. Are you running the ice in a trunk mounted tank or engine bay?
Only place where IATs become a concern to me is at the track, and I really don't make it out there as much as I'd like. I already wait about an hour between runs, otherwise just pulls about 6 degrees timing..... doesn't take much if you hotlap. I almost went the chiller route, but don't want to have to rely on AC - I had my AC crap out on me on the way to Indy Cfest when stuck in traffic 2 hrs, once I started moving things were great and never a problem again. Doesn't seem there's any huge HP guys with chillers and alot of controversy when I was entertaining the idea, plus no local shops that have done it and could support it in the long haul. Even heard talk about dual chillers and thermostatically controlled system. If it works great with a few big HP guys I might entertain it again. Thanks though.
LPE Brotherhood
Old 11-21-2012, 05:09 AM   #7
sting808
Drives: 2010 SS RS
Has anyone used the Torq reservoir with a DeWitts/BeCool radiator? Wondering if the added depth of the radiator allows for adequate clearance to the pulley/tensioner if the reservoir needs to be offset a little to clear the top radiator tank.
sting808 is offline   Reply With Quote
Old 11-23-2012, 11:04 PM   #8
Blue70SS
Blue70SS's Avatar
bump
LPE Brotherhood
Old 11-30-2012, 09:42 PM   #9
Blue70SS
Blue70SS's Avatar
Nobody has a Torq reservoir?
LPE Brotherhood
Old 11-30-2012, 11:27 PM   #10
2L82RUN
Drives: ABM SS/RS
Ive been trying to get one since March but keep being told they are redesigning the tank. So far, still no tank. :(
2L82RUN is offline   Reply With Quote
Old 12-01-2012, 10:16 AM   #11
SC2150
We have the RX Super Chiller on builds in the 700-800 rwhp range working awesome.
Old 12-02-2012, 11:53 AM   #12
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
From everything I have been hearing good luck on getting anything from Torq right now,lol.
MODS:
ADM built 417, 2.9L Whipple with 3.250 pulley, ADM ported and polished LSA heads,ADM stage3 cam,ADM LSA belt drive system,ADM CAI race scoop, ADM dual fuel pumps, ID 850's, BMR full suspension, Gforce 9 inch kit with 3.5 inch driveshaft, Street Slayer twin carbon clutch, Lingenfelter oil seperator. Tuned by built by ADM Performance, 763rwhp,705rwtq
10aSSee D is offline   Reply With Quote
