02-06-2018, 09:13 AM | #15 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The rotor isn't going to change the mu (friction coefficient) of the setup, that's what the pad is for.
02-06-2018, 01:31 PM | #16 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
As a side note, for pad selection, I'd suggest looking for pads that have more linear stopping force vs. pedal pressure that can still lock the wheels up at full pedal force rather than something that has lots of initial bite. Can't modulate pressure and control braking as easily if you go from no braking torque to lots of braking torque with barely any pedal travel.
2017 SS 1LE.
02-07-2018, 12:34 PM | #17 |
Drives: 2017 Camaro Join Date: Nov 2016
Has the O.P. considered swapping in a set of 1LE brakes?
02-07-2018, 06:04 PM | #18 |
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC Join Date: Jan 2016
I also kept warping stock rotors, I swapped to the Cquence Performance Slotted rotors and have had no issues no track since. they are noticeably heavier than the stock rotors so I imagine they are slightly more robust than the stock offerings but I am sure they are sacrificing a little bit of performance from the weight but in exchange you don't warp rotors. Plus the slotted just look the business.
02-08-2018, 08:09 AM | #19 | |
2017 SS 1LE.
02-09-2018, 08:19 AM | #20 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
I always hear people say that drilled/slotted rotors are worthless, yet Porsche, Ferrari and Lamborghini all put drilled iron rotors on their cars that are touted as being track worthy and they also offer carbon ceramic which are drilled as well.
Biggest reason for the negativeness on drilled rotors was people would buy the cheapest ones they could find and then bitch about the cracking between the holes. Even though pad technology has improved over the years, drilled rotors still offer an advantage of allowing the out gassing to escape out from under the pad and allow the pad to stay on the rotor surface more evenly. Part of the reason why if I was ever going to do a drilled/slotted rotor it would be from a high end brand, personally I am waiting for DBA to get something setup for the 1LE. I've had them in the past, they make a very high quality brake rotor. |
02-09-2018, 08:33 AM | #21 |
They sure felt heavier than stock, I will weigh the slotted but I didn't keep the factory rotors for comparison. Someone else can when they do their first brake service.
02-09-2018, 08:34 AM | #22 | |
02-11-2018, 12:30 AM | #23 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
I don't think you'll get better stopping power with the stock caliper/pad size... assuming the same pad material. I like racing brake stuff because the rotors are two-piece and noticeably lighter than stock. Had them on my old CTS-V and bought a complete set for my 135i. They're not cheap though.
They had some interesting info about the stock SS setup on their site, apparently the pad doesn't make contact with the last 5mm of the stock rotor... which seems strange. You do save 5lbs per rotor going with their setup though, not insignificant. http://www.racingbrake.com/Two-piece...ont-p/2535.htm
02-12-2018, 05:49 PM | #24 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
I wouldn't really want a heavier rotor than what already comes stock. Heat is dissipated by surface area. Weight/density allow you to soak up more heat, but it will also hold it in if the surface area isn't increased above the rate of material thickness. Holding in heat will cause the brakes to give out sooner in a track event. The rotors get hot enough they will mess with the bite of the pads.
I can agree that drilled rotors are problematic. But ball dimpling is probably superior to slots or flutes. Reason being is that in a slotted rotor, the percentage of material contact between pad and rotor is in constant flux as you pass over and between the slots. A ball dimpled rotor can have a static amount of what I would call 'engagement area' if the pattern is evenly distributed and sized appropriately based on the rotor radius and the intended pad height. While the stock pad is probably the best for track duty on the stock SS calipers, they are the worst for daily driving. Aside from dust, they have too much initial bite for a comfortable experience. And when warm, they get a little sticky on the release. Just my personal opinion. |
