Old 01-21-2018, 01:59 PM   #1
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Balancing drag radials?
I apologize if this has been covered, did not find it in a search.
Do you want or need to balance drag radials? Tire will not be used for street driving at all, track only.
Car is 2017 ZL1 A10
Wheels are 17" welds
Tires are MT ET Street R 305/45R17
My concern with balancing is there is no clearance for inside weights between rim and brakes. Any help is appreciated! This is my first time using drag radials and want to shorten my leaning curve
Thank you
Travis
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 01-21-2018, 03:52 PM   #2
Ashium
Drives: Camaro 2.0t, 300zx TT, LSTT Mustang
Are you going to drive on them daily? Many people don’t balance DR’s. If you want to balance them, have them force matched first. That will bring the amount of needed weight way down. It’s hard to tell from the pictures, but the 1/4 oz weights my shop uses are really thin and might clear. You won’t know till you try.
I’ve had to grind calipers down before for clearance, just depends on how bad you want them balanced.
Ashium is offline   Reply With Quote
Old 01-21-2018, 03:59 PM   #3
Snowblind
Snowblind's Avatar
I would definitely have them balanced. Ask them to put the weights as close as possible to the inner lip
Old 01-21-2018, 04:16 PM   #4
TDS
TDS's Avatar
No daily driving. I will put them on at the track.
What is forced match?
Good tip, thank you
Travis
Old 01-21-2018, 04:33 PM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
They make a couple different stick on weights. We have both thick and the thin weights which I have to use the thins or it will hit my calipers.
Old 01-21-2018, 04:48 PM   #6
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
There's also the style that clips on to the bead of the wheel.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 01-21-2018, 05:13 PM   #7
Ashium
Good tip, thank you
Basically instead of just randomly mounting a tire and balancing the wheel/tire together. You attempt to use the balance of the rim it’s self against the balance of the tire it’s self. The results depends on what the balance of each is, but sometimes it’s enough to not need any weight at all, to be in balance. Sometimes you’ll still need weight, but normally a much smaller amount.
Old 01-21-2018, 05:25 PM   #8
TDS
TDS's Avatar
Good to know. Your car looks great!
Good Idea
Thanks for the info, makes good since!
Travis
Old 01-21-2018, 09:18 PM   #9
396ssrat
Drives: 66 Chevelle SS
I sure balance my drag radials and they also don't get street use. I use stick on weights and metal tape over them to ensure they stay stuck. I do have more room than the wheels/calipers shown do though. So long as they clear the rotating assy you are good to go.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 01-22-2018, 04:50 AM   #10
laynlo15
laynlo15's Avatar
Thanks and yes you should balance them since your gonna be running close to 130 mph in the traps.
Old 01-22-2018, 08:56 AM   #11
lokitwitch04
Drives: 2017 Camaro SS 2SS
This may be a stupid question, but why not use the balancing gel or balancing beads? That's what I've done on all my other wheels and tires and what I use in my motorcycle tires. Is this not a good idea with drag radials? I'm about to get some, so this will be good to know.
lokitwitch04 is offline   Reply With Quote
Old 01-22-2018, 03:37 PM   #12
396ssrat
Snake Oil
66 Chevelle SS 396
Old 01-22-2018, 06:10 PM   #13
lokitwitch04
Originally Posted by 396ssrat View Post
Snake Oil
Snake oil?
Old 01-22-2018, 10:47 PM   #14
396ssrat
Snake oil?
Something which is designed to make you spend money which is like buying something on TV such as a water powered flashlight. S C A M
Yes, I have heard about the beads but they aren't recommended for racing. I wonder why that would be...
Here is a link to read
http://www.innovativebalancing.com/LowProfileTires.pdf
66 Chevelle SS 396
