05-28-2022, 11:34 PM | #1 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Wtf BMR
So am I missing something here ? I was adamant to bmr that I had a zl1 - so why the problem with last bushing .. smh I thought bmr had their stuff together ..
Can I cutt the bushing to be able to fit in ? Or am I just screwed cause of bmr sent me the wrong stuff .. Man I’m getting tired of dealing with parts guys Any insight to this I would appreciate it . As my diff is sitting on the floor till I figure this out |
05-29-2022, 12:25 AM | #2 |
Drives: '11 2SS/RS LS3 M6 (Sold) Join Date: Dec 2015
The diff bushings for the SS and ZL1 should be the same. They likely just need a little lube and pressure and they’ll go right in.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. |
05-29-2022, 12:52 AM | #3 | |
And tbh I’m installing the delrin cradle bushing kit as we speak and I’m almost regretting buying them , cutting off and reusing the top hat of the stick bushing and cleaning the rubber off is the pain in the ass !! Imho bmr could of done a better job , like Hendrix or some sort .. I’m pretty pissed off at bmr |
05-29-2022, 01:06 AM | #4 |
Hmm bmr has crappy direction , they don’t even stay where to cutt the top hat so I cutt in the middle , and it’s almost square instead of round .. smfh
05-29-2022, 05:52 AM | #5 |
So the front cradle you have ti cut the top hat flush , the rear you’ll see when you cutt the rubber off where to cut the top hat apart at .. sure would of been nice if bmr would include that in the instructions ..
When knocking in the diff bushing I noticed that one of them was letting go alittle bit of skin , guess it kinda scraped some off . Which kinda mind boggles me as I cleaned and sanded the hole down and made it smooth .. Unless someone here knows what’s going on I won’t be able to out my diff back until Tuesday when bmr opens up . What a bunch of bullshit Spend 1200.00 for some rubber and you’d figure it wouldn’t be a problem !! I mean this isn’t a new product |
05-29-2022, 09:06 AM | #6 |
Looks like ss and zl1 have different a diffs ..
05-29-2022, 09:45 AM | #7 |
Take it from me , trailing arms and toe rods are ok from bmr but for bushings I’d go somewhere else ..
Unless you don’t mind doing more work than you have to .. I mean look at the mess cutting the bushing apart left Last edited by Risingson05; 05-29-2022 at 09:59 AM. |
05-29-2022, 02:00 PM | #8 |
Drives: 2010 ss Join Date: Oct 2015
just taper the end of the bushing with a grinder and use ready rod to pull them in
05-29-2022, 02:11 PM | #9 |
05-29-2022, 02:50 PM | #10 |
Drives: 2012 SS Join Date: Dec 2021
sometimes freezing it will shrink it enough to fit.
2012 Camaro SS
05-29-2022, 03:26 PM | #11 |
05-29-2022, 04:46 PM | #12 |
Drives: 2013 ZL1 Join Date: May 2019
05-29-2022, 08:51 PM | #13 |
Got it done ! I ended up having to put a 1/8 notch on the lip of the bushing after tapering the end down alittle . I went and got a piece of 3/4 all thread , 3/4 washer and 1 1/2 washer 3/4 nuts , did the trick .
05-31-2022, 07:53 AM | #14 |
Drives: 2013 ZL1 Join Date: Jan 2020
To anyone reading this thread and looking at the BMR stuff- consider using Detroit Speed.
Yes, the Detroit Speed stuff is more expensive. It is also much nicer is every way. |
