06-17-2015, 06:46 PM | #1 |
Drives: 2013 Triple Black ZL1 Join Date: Dec 2014
Did fuse pull, got check engine light
Did the npp f8 fuse pull and it worked perfectly. However the next day it gave a CEL so I put it back in and drove it. The light will not turn off. How do n I fix this and why did it occur. The car has about 2500 miles.
06-17-2015, 06:48 PM | #2 |
Drives: 2017 Red Hot ZL1 Join Date: May 2015
Take it to autozone and have them read the code for you and re-post what the CEL is.
06-17-2015, 06:59 PM | #3 |
OWTATIME
Drives: 1969 CaRaMo Join Date: May 2009
It shouldn't be from the exhaust. I've done it on 3 cars and never had one to come on. I would get it checked at a local parts store like stated above
06-17-2015, 07:17 PM | #4 |
Now the flaps do not work even with the fuse in. I just checked the relay in the r2 slot and it's good but the terminal has no ground going to the relay. Is there a wiring diagram of this area in the trunk? The flaps will work if I connect the battery to the relay terminal.
06-17-2015, 07:22 PM | #5 |
OWTATIME
That is out of my realm of knowledge there. May wanna visit your dealer and see if they have any answers.
06-17-2015, 07:26 PM | #6 |
Drives: 2015 Blue Velvet Metallic ZL1 Join Date: Nov 2013
Gotta ask....you did pull the #8 fuse from the fuse box in the trunk and not from the fuse box under the hood?
06-17-2015, 07:37 PM | #7 | |
