Vararam
Old 11-19-2012, 01:25 AM   #1
velocity149
velocity149's Avatar
Drives: 2014 2SS RS LS3
So, I think I need some help...
Hey guys, got me new camaro, and put 800km on it in 5 days. Tried out sport mode and tap shift. I see that it holds the gears longer than drive when it's in sport mode. So tonight, I drove about 20 minutes so the car was hot, and when I got back in the car after getting groceries, I felt the car hold the gears longer like it was in sport mode. Thought nothing of it, until I was at about 60k/h an it shifted into 1st and shut down. I did NOT hit the tap shifter, and it was in drive. Now, it always says M* when I am in drive, and I can't get it to stay in drive. Any help is appreciated. I have a 2lt RS 2012 with 800km
Thank our veterans for peace today, Support our troops for peace tomorrow. RIP Dad, 1962-2012 SYOTOS
velocity149 is offline   Reply With Quote
Old 11-19-2012, 01:33 AM   #2
SoCalCamaro93
SoCalCamaro93's Avatar
Drives: 2016 2SS, 2011 RS (past)
The only thing I would say is maybe you accidentally hit the paddle shifter...but you say that you didn't so I honestly do not know. When my car is in sport mode(M) it displays an S and while in drive it displays a D
Past: 2011 RS, 2013 ZL1
Current: 2016 2SS
SoCalCamaro93 is offline   Reply With Quote
Old 11-19-2012, 01:41 AM   #3
velocity149
Ya, when you drop the shifter past d, an S comes up on the dic. That's sport mode, it just holds shifts longer, and feels more sporty. Then when you use the shifter, it will come up M (whatever gear). Mine is stuck in the M mode, even when I put the car in drive.
Old 11-19-2012, 01:45 AM   #4
SoCalCamaro93
Ohh okay I get it. It's probably just a problem with the cars display then...possibly got stuck..?I would take it in and get it checked for sure
Current: 2016 2SS
Old 11-19-2012, 06:05 AM   #5
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
That's is a little strange because on the A6 the shifts are computer monitored so if the computer believes the shift will either be to High or low in the rpm bands it either wil not let you shift or it will shift down for you. Atleast that's how the 12 SS I drove felt like. I can't really help as I have manual car.
Old 11-19-2012, 08:26 AM   #6
usafboy
usafboy's Avatar
Drives: 2010 Silver SS/RS LS3
Even after turning your car off and back on it still shows the M? Does it show it when you shift all through PRNDM?
2010 Silver Ice Metallic Camaro SS/RS LS3
Mods...so far: resonator/muffler delete, tinted everything, '13 shift knob/boot, bowtie delete, PFADT sway bars, CAI intake, Hurst short shifter, JBA cat deletes, BMR trailing arms/outer bushings/steering rack bushing, Bo White ported TB.
Rhino79 Dyno tuned...405 HP/399 TQ
usafboy is offline   Reply With Quote
Old 11-19-2012, 08:31 AM   #7
JustCraig
JustCraig's Avatar
Drives: 07 Super Bee #587 & 07 Tahoe
Take it to the dealer. Let them figure it out. Keep us posted!
~Craig
JustCraig is offline   Reply With Quote
Old 11-19-2012, 10:57 AM   #8
nikos30
HT5 EastSide
nikos30's Avatar
i would try disconnecting the battery for 30 mins. if that didnt work, then I would bring it tot the dealer. good luck
nikos30 is offline   Reply With Quote
Old 11-19-2012, 11:31 AM   #9
JustCraig
JustCraig's Avatar
I thought about that, but I would want the dealer to document that it happened in the first place. If you disconnect the battery and it fixes it, you have no proof that it ever happened.
~Craig
Old 11-19-2012, 11:32 AM   #10
nikos30
HT5 EastSide
nikos30's Avatar
ok so then make a video of it happening before you try it
Old 11-19-2012, 11:42 AM   #11
Heaven_is_inferno_orange
Savage Setsuna
Heaven_is_inferno_orange's Avatar
Drives: 16' 2SS, 12 ZL1, RIP Sasuke
Send a message via MSN to Heaven_is_inferno_orange Send a message via Yahoo to Heaven_is_inferno_orange
Not nessecarily. It's possible the problem will set a code into the history. Not everything that sets a DTC will illuminate a MIL to let you know. But if a DTC has been set it will remain in history until either it is erased via scan tool or the car has completed 40 trips without failure. My advice though would still be to take it into the dealership. Usually when a auto trans vehicle goes into 1st and wont come out its put itself into limp mode. Could be a number of things wrong.
Heaven_is_inferno_orange is offline   Reply With Quote
Old 11-19-2012, 11:44 AM   #12
JustCraig
JustCraig's Avatar
I stand corrected. Thanks!
~Craig
Old 11-19-2012, 12:55 PM   #13
BlueRay-J
BlueRay-J's Avatar
Drives: 2013 Camaro SS Convertible
Try holding the right paddle for a couple of seconds, which exits manual mode while in Drive (and I think returns to automatic sport mode while in S). Usually, the car will do this automatically, but maybe you have a bad signal wire or paddle that makes the car think its receiving constant paddle input.
BlueRay-J is offline   Reply With Quote
Old 11-19-2012, 03:47 PM   #14
velocity149
Held the plus paddle, and it returned to normal! Restart the car, and it's back into m mode. Could it be the shift lever linkage is improperly adjusted? It would think it is in the m position when it's in the d position?
