04-22-2024, 10:00 PM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
What can cause this?
Ran gates green belt, but it keeps shredding on me. That's usually if I do so hard pulls. But on a regular cruise, it's fine. Switched to a regular gates belt since shits getting expensive.
Anywho... help me diagnose this. I think it was doing the same with the gates green belt, but I just never paid attention. It may seem like.... - the belt is too long, but it's the same series and same length - pulleys are not aligned, they're aligned. Straight edge and laser confirmed. - tensioner is not providing enough tension, that bad boy is tight as tight can go. - SC pulley spins freely, no wobble, checked other pulleys also and they're good. https://youtube.com/shorts/-w1iUS7IW...Y5Cq0yorp7jjyo
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-23-2024, 06:04 AM | #2 |
Drives: 2010 Camaro SS Join Date: Dec 2006
That long run of your belt on the bottom off that video looks like it’s a little sloppy and flapping around. Is it slapping against something down there? You may need more tension. These belts stretch more than you’d believe under high rpm and load. Go see some videos of that on YouTube. Kind of amazing how far they can balloon out. My guess is that your belt is contacting something under high rpm/load and stretch and it’s shredding it up.
I put a JRE Supertensioner on mine and it’s a nice piece. |
04-23-2024, 07:23 AM | #3 |
Drives: 2013 1ss Join Date: Jul 2012
Are there any witness marks on the belt showing an impact? Can you tell if it is breaking in a certain pattern like edge toward center or center toward edge? Do you have any close ups of the broken portion of the belt?
04-23-2024, 09:52 AM | #4 | |
The belts shred in 2-8 pieces, so no idea.
04-23-2024, 11:10 AM | #5 | |
04-23-2024, 06:30 PM | #6 |
Thanks. I disassembled the tensioner and 1 of the idler pulleys and tinkered with it a little. Lo and behold I was able to get it tighter. Hopefully no more shredded belts.
https://youtube.com/shorts/xYkD3Bxau...kOAA3SgBtX_hBJ
04-24-2024, 11:48 AM | #7 | |
04-24-2024, 11:59 AM | #8 |
That's the supercharger pulley. Looks wobbly but it isn't.
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq Last edited by RupertPupkin; 04-24-2024 at 02:22 PM. |
04-24-2024, 12:11 PM | #9 |
Oh wow!! That thing is wobbling quite a bit, looks like. I've not looked at any of my friends SC setups to see if that is normal or not, but keep an eye on it. The rest of the belt and tensioner look great though. Hope what you did works out. Gotta be frustrating.
04-24-2024, 02:26 PM | #10 |
I think with the camera so close and all the crap that was in the pulle (belt residue/dirt) gave the illusion of the wobble.
04-26-2024, 08:55 AM | #11 |
Is there room to add another pulley where its moving around to take some deflection out??
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
04-26-2024, 09:17 AM | #12 | |
I did do a WOT til 5500-6000rpms and no issues. That's where the belt will usually break.
04-26-2024, 10:32 AM | #13 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
This may or may not be a little off topic, but I picked up a Gates RPM High Performance serpentine belt since I couldn't find the green HD belt (over the regular belt). I reckon it's supposed to stretch less, not sure. I wonder how daily friendly that RPM belt would be?
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
04-26-2024, 02:05 PM | #14 | |
