Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-27-2013, 05:10 PM   #1
ayousef
ayousef's Avatar
Drives: 2013 ZL1
Arrow let the pictures do the talking [COTW 7/22/13]
Did 900+ rwtq at 4300rpm and 984rwhp at 6200rpms, couldnt spin higher since we ran into a problem with the dual throttle controller that were currently working on. This was on pure 93 octane pump gas no meth, but we do have a meth system on the car. Will definitely make a 1000rwhp on pump gas with a small cam.
Someone said I have one of the baddest cars in the universe, exluding planets other than the earth. Exaggerating or not that was cool of him to say
Okay im sure um gonna miss more than a few details of this car but here goes:
- We begin with an RHS 427 block, built by LME using custom diamond pistons, ceramic coated tops and antifriction coated skirts. Billet Oliver rods, and Callies Dragonslayer crankshaft
- Mast 305cc LS7 12degree heads, the best LS heads money can buy. Fitted with PAC 1521 dual springs (awesome springs FYI), 1.7 rockers with trunion upgrade, and Stainless steel intake and exhaust valve (hollow intake stem).
- Whipple 4.0 obviously, sand rail kit which is why its HUGE cause it has a huge intercooler that it sits over. Custom CNC'ed dual induction airbridge, believe it or not this is most likely the most expensive single part on the car.
- Dual ported 87mm throttle bodies, and dual 4" cold air intakes routed to the brake duct openings
- Meth kit with hardline meth tubes, as shown in the images.
- Aeromotive Eliminator fuel pump with fuel pump speed controller, regulator, hardlined fuel feed and fuel rails.
- ID1000 injectors
- American racing headers 2" long tube headers, 3" merge collectors + x-pipe
- B&B fusion exhaust full 3" exhaust including butterfly valves. Custom switch to gain full control of butterfly valve operation.
- Hendrix Engineering RPS triple disk clutch, rated at 1200rwtq
- Fully built RPM transmissions TR6060
- Ron Davis custom radiator utilizing stock fans because the stock fans are awesome.
- HUGE KDi intercooler heatexchanger
- Meziere 20gpm intercooler pump + custom intercooler reservoir tank (despite the biased opinion from Lingenfelter the pump works flawlessly)
- Custom clutch fluid reservoir separated from brake reservoir
- Pfadt ZL-spec sway bars
- Dual DBW throttle body controller
- Hptuners 2.5bar OS
- MGW short throw shifter
- Custom camshaft from Flowtech Induction
- Custom MPD1 cowl hood, awesome quality and built using a special high distortion temp resin in effort to avoid any fiberglass deformation due to excessive engine or ambient heat.
Im sure I missed a lot of stuff no kidding.
Brakes are getting upgraded, rear seats removed, lightweight battery, slight additional suspension/chassis mods, 18inch wheels + proper tire setup, carbon fiber front fenders, and hood redone in carbon fiber (possibly), plus a custom tubular front crash support since we removed the factory one which blocks a big deal of airflow to the intercooler/radiator.
EDIT: forgot about the driveshaft shop carbon fiber driveshaft.
dont have anything too interesting but here goes
1150bhp Whipple 4.0 Supercharged 427ci Camaro ZL1
ayousef is offline   Reply With Quote
Old 05-27-2013, 05:36 PM   #2
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
I like it.
Smittty is offline   Reply With Quote
Old 05-27-2013, 05:45 PM   #3
ROD_SS
ROD_SS's Avatar
Drives: 2013 1SS Camaro and a truck
ADM tuned (465 rwhp / 442 torque) Mods- CAI, kooks long tube headers, & ADM stage 2 cam
ROD_SS is offline   Reply With Quote
Old 05-27-2013, 06:02 PM   #4
zl1bro
Drives: 2013 ZL1 M6 SIM AGM mono stripe
Holy shit!
zl1bro is offline   Reply With Quote
Old 05-27-2013, 06:10 PM   #5
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Wow!
Deke736 is offline   Reply With Quote
Old 05-27-2013, 06:16 PM   #6
stikSS
9691 & 97586
stikSS's Avatar
Drives: 2010 SS, 1999 SS, 1993 Z28
:eek: SON OF A BITCH!!
Sent from my Apple sued Galaxy Note 2
stikSS is offline   Reply With Quote
Old 05-27-2013, 06:21 PM   #7
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
I would love to hear this monster come to life, please give us a sound clip!
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 05-27-2013, 06:34 PM   #8
Gen-X45
Gen-X45's Avatar
Drives: 2017 2SS Camaro
A work of art to say the least... really nice, post a vid or two when you're out running sometime.
Gen-X45 is offline   Reply With Quote
Old 05-27-2013, 06:43 PM   #9
#737 ZL1
Drives: 2012 ZL1
Bycrumba, what a nice job
#737 ZL1 is offline   Reply With Quote
Old 05-27-2013, 07:05 PM   #10
GAZL1
Drives: 2013 ZL1
Nicely done! Very impressive looking!
GAZL1 is offline   Reply With Quote
Old 05-27-2013, 07:10 PM   #11
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Sweettttttttttt.....
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-27-2013, 07:17 PM   #12
BDBiker
BDBiker's Avatar
Drives: Black 2013 2SS/RS 1LE
Bad to the bone!
BDBiker is offline   Reply With Quote
Old 05-27-2013, 07:21 PM   #13
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
Dayum!
Mind controlled by Cerebro
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 05-27-2013, 07:25 PM   #14
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
VIDEOS PLEASE!!!
Al C. is offline   Reply With Quote
