Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 08-14-2014, 07:43 AM   #1
M3hta1
USMC OIF 06-08
M3hta1's Avatar
Drives: My wife crazy!
Will 20x10 +35 Offset Fit
I am looking to pick up some new wheels. Will the 20x10 +35 fit on the front and rear? I want to go with a squared stance with the ability to rotate my tires.
Will be using my oem wheels to get some drag radials for the track.
M3hta1 is offline   Reply With Quote
Old 08-14-2014, 09:10 AM   #2
Meister
Meister's Avatar
Drives: 2016 Corvette Stingray Z51
Yes. That is the same set up I have on mine now with Factory Reproduction wheels and Nitto INVO tires. Might be getting coilovers next to lower a bit.
2016 2LT Corvette Stingray Z51 7MT:
Torch Red, Adrenaline Red/Black interior, Nav, PDR, black wheels, Carbon Flash trim.
Current mods: Permagrin!
Meister is offline   Reply With Quote
Old 08-14-2014, 09:14 AM   #3
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
If you have coilovers it may or may not fit. If you have stock struts and no plans to get coilovers then you are good to go depending on the wheel. As it may or may not clear the brakes.
CHMSC is offline   Reply With Quote
Old 08-14-2014, 09:21 AM   #4
IneedAZ
IneedAZ's Avatar
will depend on the wheel u choose. I had to go with a 20mm offset cause the spokes would hit the calipers going larger offset. I had to choose, either stay with that offset or put my v6 calipers back on.
Old 08-14-2014, 12:09 PM   #5
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
I've got 20x10.5 front and rear on bags . They will fit. Lol.
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Airlift Suspension V2
Niche Targa 20x10.5
Chris14RS is offline   Reply With Quote
Old 08-14-2014, 12:21 PM   #6
M3hta1
USMC OIF 06-08
M3hta1's Avatar
I talked to the manufacture and the +23 won't fit on the front. So I decided to go with the factory reproduction stain black 20x10 +23 for all 4 so I can rotate my tires and get more life out of them.
Old 08-14-2014, 12:27 PM   #7
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
Here's my FR 20x10 +35 squared set up. +35 will fit up front.
760bowtie is offline   Reply With Quote
Old 08-14-2014, 12:57 PM   #8
1BDS5GEN
Drives: 2014 camaro ls
Here is mine on 20x10.5 +30 offset on all 4 corners.
1BDS5GEN is offline   Reply With Quote
Old 08-14-2014, 02:17 PM   #9
IneedAZ
IneedAZ's Avatar
Attachment 654097
what size rear tire? any shots of the fenderwell and tire? wanted to see how close to the edge a +30 is cause my +20 with a 295/30 PSS tire sticks out almost an inch from top view.
Old 08-14-2014, 10:09 PM   #10
1BDS5GEN
Here are a few different angles I have. Car is lowered 1 inch in these pix. Tire size is 275/40/20 in front and 315/35/20 in back.
Old 08-15-2014, 08:14 AM   #11
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
20x10.5 +35 All around.
Magnaflow X - pipe
MRT V2.0
CAI Intake
BARTON SS
Niche Targa 20x10.5
Old 08-15-2014, 09:22 AM   #12
Cldgin2
Cldgin2's Avatar
Drives: 2017 1LE SS
This thread was a god send btw.... Helped me decide. Order may be going in today
Cldgin2 is offline   Reply With Quote
Old 08-15-2014, 09:25 AM   #13
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
My 315 set up actually hits in the rear on big bumps at speed just barely but I'm lowered 1 inch
revived is offline   Reply With Quote
Old 08-15-2014, 09:27 AM   #14
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
@chris14rs bagged... wow!
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
