11-17-2014, 01:08 PM | #1 |
Drives: '10 SS Join Date: Nov 2011
Car shifting on it's own?
Hi all, didn't know if this was the right section but earlier I was at a red light and I needed to accelerate fast enough to get into the next lane. I hit about 70 when the upcoming light was red so I had to slow down breaking kinda hard, in the process my car shifted into neutral on its own. So I had to pull off to the side to shift it back in to drive and keep going. And before this a few months ago I accelerated fast to get into another lane (cutting someone else off) and in the process of hitting a sharp turn the front tires started to swerve left and right until I had to break and stop to gain control and in the process the car shifted into neutral. Any idea why this keeps happening? Once I had a message pop up saying service stability control but went away once I turned off and restarted the car and hasn't showed up since. Any help beside being more careful would be grateful lol. Thanks in advance
11-17-2014, 01:13 PM | #2 |
Drives: 2018 Camaro 1LT Hyper Blue Metallic Join Date: Nov 2013
Sounds like your Stability Control.
(Sorry, couldn't help it.) |
11-17-2014, 01:16 PM | #3 |
Sounds like you need to learn how to drive more responsibly before you kill someone.
11-17-2014, 01:52 PM | #4 |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
Sounds like your shitty driving messed up the transmission.
11-17-2014, 01:56 PM | #5 |
Drives: Black 14 2SS/1LE/RS 14 Tundra Join Date: Dec 2013
11-17-2014, 01:57 PM | #6 |
Haha that's what it may seem. But if you really don't have anything else to say beside my driving don't bother posting bro.
11-17-2014, 02:01 PM | #7 |
Drives: 2010 camaro SS... shell... Join Date: Nov 2012
Sounds like your car is telling you "you're an idiot.".
...I'm siding with the car. Don't like it? Then Sell the car, get a Honda, LEARN TO DRIVE, then work you're way back up to responsibility and then get a manual transmission. Stop giving the rest of us a bad rep.
tried LSXTC...now I'm LSXOD...
11-17-2014, 02:03 PM | #8 | |
11-17-2014, 02:16 PM | #9 |
Well, it is possible that your driving has something to do with the problem you described. No doubt you hit high rpms doing this... it could be you rev limiter. Are you sure it shifted into neutral, or did the engine just cut off?
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
11-17-2014, 02:20 PM | #10 |
Silver Ice
Maybe your mommy instincts are kicking in and youre doing the "put arm across passengers stomach to prevent from flying out the window" type deal and not realizing your putting your car into neutral.
11-17-2014, 02:28 PM | #11 |
Drives: 2011 2SS/RS A6 Join Date: Sep 2014
Your car is obviously equipped with ODP (Other Driver Protection) and the erratic driving is causing that system to engage and remove power from the car off until you stop.
11-17-2014, 02:48 PM | #12 |
No I didn't shift it myself my hand was no where near the shifter. And 95 percent of the time I do respect the rules of the road it's just that 5 percent when I'm in hurry lol
11-17-2014, 02:50 PM | #13 |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
Sounds like you are getting thrown around and bumping it into neutral. There is nothing electronic that will move the gear shifter out of drive.
You don't need to pull over to put it back in drive. Also, quit driving like an idiot around other drivers.
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
11-17-2014, 02:51 PM | #14 |
Drives: 2012 LS Join Date: Apr 2013
Keep digging that hole
