Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Autos For Sale / Wanted
Old 06-05-2012, 02:41 PM   #1
aet08
Drives: c
AET08 going up for auction. 900HP
AET08 2010 Camaro SS is going to be sold at the upcoming O.C. Barrett Jackson. NO RESERVE
http://www.barrett-jackson.com/appli...?ln=64&aid=464
specs
Engine Mods - 6.85L (418ci)
4" Stroker Crank 4.080" Bore
Camshaft .566 .569 Lift and a 121 LSA
FAST Fuel Rails
Fuel Lines: -6 Hard Line for Return and -8 for the Feed
ARP Crank bolt, Cam bolts, Mains, Rods, Head Bolts
BDL indexed cam sprocket and ARP cam bolt
GMPP LS3 conversion - lifters, lifter trays, chrome moly push rods, hardware
GM OEM LS3 lifter valley plate
GM OEM LS3 front cover, aluminum
ARP head studs
GM OEM multi layer steel head gasket set
Oversized stainless steel intake/exhaust valves
Double valve spring kit with chrome moly locks/retainers
1.8 Ratio Yella Terra rocker arm system
Stage III cylinder head port/polish. Port match, 5 angle valve job,
resurface, bronze bullet nose valve, guides, bowl reshaping.
Forged Short Block, Scat crank, H-Beam Rods, JE
Pistons, Clevite Bearings, ARP Main Studs, ARP Rod Bolts, Melling Oil Pump,
Double Roller Timing Chain set, ARP Crank Bolt, New Freeze Plugs.
Exhaust
KOOKS Complete exhaust system 1 7/8" Headers
Suspension
Pfadt Camaro Road Racing Kit - Stage 4
Pfadt Racing Camaro Adjustable Rear Tie Rods
Pfadt Camber Kit - 2.5" Springs
Drive train
DSS Level 5 axel shafts - 1400hp
Century Transmission 6L80E Super transmission build
Body Work
Custom full-body stripes: Front/rear bumpers, hood, roof, and wing.
(Aston Martin's Morning Frost White)
MPD1's Rear Wing
MPD1's Z Force Ran Air Hood
T3 front bumper ports w/ LEDs
GM Heritage grill
LED Turn signals
Wheels & Tires
Savini Forged Monoblock SM2 - Brushed -- 20" Diameter.
Width: 11" Rear, 9" Front
Rear Tires: Nitto NT05R 315/35R20
Front Tires: Nitto INVO 245/45ZR20
Forced Induction/Cooling
YSI V7 Vortech Race Blower w/cog pulley upgrade 7" crank cog, 32 tooth supercharger pulley
Meziere electric water pump
Fuel system/Intake
Aeromotive A1000 Fuel Pump
FAST 80lbs fuel injectors
FPS steel braided fuel lines and -8 AN fittings
Aeromotive 5/8" ID billet fuel rails with LS brackets for FAST manifold
NGK TR6IX spark plugs
F.A.S.T. LSX intake manifold
aet08 is offline   Reply With Quote
Old 06-05-2012, 02:58 PM   #2
Ivan @ Southwest Speed
Drives: '15 Z06, '01 NBM SS, '97 SS
GLWS! Has always been one of the nicer cars on C5.com.
Ivan
Ivan @ Southwest Speed is offline   Reply With Quote
Old 06-05-2012, 03:03 PM   #3
aet08
Drives: c
thanks Ivan
Old 06-05-2012, 03:15 PM   #4
1954 Belair-man
1954 Belair-man's Avatar
Drives: 2010 Camaro IOM 1SS M6
Lot #64, does that mean its the 64th car to be on the block?? Good luck and i hope you get what you wanted for it, i'll more than likely be watching.
1954 Belair-man is offline   Reply With Quote
Old 06-05-2012, 03:34 PM   #5
aet08
Drives: c
yes more or less, 64th car up on the block. On friday
Old 06-05-2012, 03:38 PM   #6
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
I wish, I love that Camaro, and the sound of that Supercharger is music to my ears
Old 06-05-2012, 09:05 PM   #7
doc212121
Drives: 2016 Camaro 2SS White/White
I'd buy it privately but never at a BJ sale
GL
doc212121 is offline   Reply With Quote
Old 06-06-2012, 07:54 PM   #8
goshawk823
goshawk823's Avatar
Drives: 2017 RS convertible
I Love your car. Absolutely beast. GLWS.
Camaros I've owned:
1969 RS/SS Z10 Indy Pace Car - Hardtop 1 of 250
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
2017 Camaro 2LT RS convertible
goshawk823 is offline   Reply With Quote
Old 06-11-2012, 01:58 PM   #9
aet08
Drives: c
anyone from Camaro5 going to the jackson show?
Old 06-21-2012, 01:26 PM   #10
aet08
Drives: c
up on the block tomorrow!
Old 06-21-2012, 06:36 PM   #11
goshawk823
goshawk823's Avatar
good luck selling it.
such a beautiful car...
Camaros I've owned:
1970 Camaro
2010 2LT RS
2013 2SS RS
Current ride:
Old 06-22-2012, 05:09 PM   #12
Birm
Birm's Avatar
Drives: Florida Speed & Power
Ivan
Rephrase needed, the NICEST car on c5
Glws..This has been my favorite car for a while.
Birm is offline   Reply With Quote
Old 06-22-2012, 07:23 PM   #13
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Just showed it, coming up shortly.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 06-22-2012, 08:22 PM   #14
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
43,000 ouch.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
