TireRack
Old 06-19-2022, 06:17 PM   #1
Archer428
Drives: Camaro
2010 camaro HID headlight replacement
For the ones that had to replace your headlight assembly due to the bad design of the factory system
What did you go with on the replacement?
What did you go with that you were happy with the end result
I have thought about just going with an after market set to jeep it easy on the installation
Or is it worth it to do a retrofit projector setup, if you went with the projector conversion what setup did you use
Archer428 is offline   Reply With Quote
Old 06-29-2022, 03:07 PM   #2
Sparko
Sparko's Avatar
Drives: 2010 Camaro 2SS
TheRetrofitSource is a good retrofit company. They have a forum they are, associated with I guess (HID Planet), that offers a lot of assistance for retrofitting. I did a retrofit years ago with their products and they were pretty helpful with answering questions and I was able to get everything I needed through them.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 06-29-2022, 04:13 PM   #3
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Didn’t see any selection for HID headlights, only Halogen
camguynj is offline   Reply With Quote
Old 06-30-2022, 09:56 PM   #4
Jbcamaro
Jbcamaro's Avatar
Drives: 2010 camaro
It’s been done with HID. Research it on the forum and you will eventually find it.
Jbcamaro is offline   Reply With Quote
Old 07-03-2022, 11:33 PM   #5
Rob99
I’m Magik a physco dog
Rob99's Avatar
Drives: '15 1LT/RS & '23 3LT/RS
I was also searching for a complete replacement not just the bulb, came across this company where from what I’m seeing on their website is a complete unit swap, these are 6 Gen looking that fit on the 5th Gen might be worth considering if you don’t mind losing the ‘halo rings’ since I haven’t found a better built halo style I would consider this 6 gen style.
Next gen speed . Com
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe.
Previous:
2015 1LT Ashen Grey
2016 1LT Blue Velvet
My entire life has been 'A Midlife Crisis'
Rob99 is offline   Reply With Quote
