TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 04-30-2023, 05:47 PM   #337
Aqua10
Drives: 2013 Camaro ZL1
Originally Posted by Aqua10 View Post
Fuel fell on face so have a fore triple pump system on the way. She’s hangry for more. This was on 93 with 13* timing.
Upgrades this round plus the Fore system
Aqua10 is offline   Reply With Quote
Old 05-01-2023, 10:46 AM   #338
NicKey
NicKey's Avatar
Drives: Nickey Super Camaro
NicKey Performance Stage II, ported heads & Our Stage II Cam, 2650R and supporting mods. e85 and stock bottom end.
NicKey is offline   Reply With Quote
Old 05-26-2023, 11:25 AM   #339
Aqua10
All finished up!
2013 ZL1 - LME 377 | LME PORTED Heads | 235/251 .637/.632 Cam | Kong X-Port | RotoFab Big Gulp intake | NW103 | Fore Triple pump | TSP Headers | Corsa Exhaust | 2.35 Upper and 9.65 lower Pulleys | E85 | PowerFab Tune
Old 06-19-2023, 06:35 PM   #340
KornHub12
Drives: Chevy Camaro ZL1
Latest dyno pull
Dyno jet was 926whp 848wt
Mustang 797whp 706wt
4300 DA
88* out
61% ethanol
I can’t remember where we stopped on timing
64% duty cycle
38,000 on body
6,100 on motor
388 LSA weisco rods, diamond pistons, btr custom grind cam, ARP hardware through out, 2.45 upper, 9.17 lower, 100mm idler, Dsx relocation bracket, gates rpm belt, Jokers race port, 103 TB, roto-fab big gulp, Frankenstein stage 2 ported heads, Texas speed 2” headers in to corsa, Afco heat-x, 2 gal expansion tank, lingenfelter 2 step, auto-blip, line lock, switch link, ID 13** injectors, DSX auxiliary system with upgraded larger Bosch pump, Dsx flex fuel sensor, stock trans, rear end, half shafts, drive shaft, dyad clutch for now.
KornHub12 is offline   Reply With Quote
Old 06-22-2023, 09:58 AM   #341
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Originally Posted by KornHub12 View Post
Attachment 1129359
4300 DA
88* out
61% ethanol
64% duty cycle
38,000 on body
6,100 on motor
WOW!
926 on a Dynajet
797 on a Mustang
That's a pretty big difference between dynos
FasNuf is offline   Reply With Quote
Old 07-02-2023, 10:01 PM   #342
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Originally Posted by FasNuf View Post
WOW!
926 on a Dynajet
797 on a Mustang
Yep, almost a 15% difference. You proved on my last dyno that the Dynajet is always higher. What most people do not understand is that the Dynojet uses a weighted drum, they all weight the same so Dynojet to Dynojet there is a very small difference in reading between them when set up the same. Other dyno's not so much.... That is why I do the math to have my results read close to the Dynojet!
Vicster is offline   Reply With Quote
Old 07-02-2023, 10:38 PM   #343
Little Walter
Drives: ZL1
All finished up!
Very impressive, is this a auto tranny or M6?
Little Walter is offline   Reply With Quote
Old 07-14-2023, 10:21 AM   #344
Aqua10
Auto
Old 08-06-2023, 09:10 PM   #345
Navajo415
Navajo415's Avatar
Drives: 2015 Camaro ZL1
I got 528hp/540tq with the mods in my signature
Catless 1 7/8” kooks long tube headers, TR7IX spark plugs with MSD spark plug wires, Rotofab CAI, washer fluid relocator, metco solid isolator, 2.50” upper pulley, PLM heat exchanger, LSA reinforced brick, elite engineering catch can, FIC1000 injectors, DSX flex fuel, DSX aux pump, custom dyno tune
Navajo415 is offline   Reply With Quote
Old 02-07-2024, 02:01 PM   #346
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
Bone stock 2013. Just hit 22k miles on the way to the dyno.
Edited for updated dyno.
2inch Lt headers
Rotofab intake
FIC 1200cc injectors
DSX aux pump
DSX 9.25(18%) lower
E85
Kings2010 is offline   Reply With Quote
