11-03-2021, 05:11 PM | #1 |
Drives: 2017 Camaro ss Join Date: Oct 2021
Does anyone know what this part is? (Oil leak)
Hey I am new to this forum but I had a question regarding my car. I have a 2017 Camaro ss and I noticed that it has an oil leak. When I went under the car I noticed that it was leaking from this part but idk what it is called and why it happened. If someone could tell me what the part is called and how to fix it that would be much appreciated. The leaking is coming from on the side of the oil plan from that nut as shown in the photo. Thank you and please let me know.
11-03-2021, 05:37 PM | #2 |
Drives: 2021 300 Join Date: Jan 2015
Pull back so we can see where on the car your looking at.
11-03-2021, 05:50 PM | #3 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Engine oil cooler
11-03-2021, 06:00 PM | #4 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Put a wrench on that bolt and see if its tight. That is the Engine oil cooler.
11-03-2021, 06:08 PM | #5 |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
That's the water-to-oil oil cooler, to be more precise. SS has additional air-to-oil oil coolers in the front but that's beside the point.
As others said, check the bolt's tightness. If the bolt's tight then it's either a gasket or something is cracked somewhere.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
11-03-2021, 06:11 PM | #6 |
gotcha thank you everyone, is it easy to replace the gasket on these or no?
11-03-2021, 11:13 PM | #7 |
Drives: 2018 Camaro SS 1LE M6 Join Date: Oct 2018
If I’m not mistaken, the dip stick is right above that…. I’d make sure it is seated correctly if have removed it in the past to install headers or whatever.
Camaro 2SS 1LE, MBRP Catback, Mishimoto Catch Can, Rotofab dry, TSP1 7/8” headers,DSX FF, Pray ported MSD, 95mm TB
492WHP 473WTQ |
11-04-2021, 08:20 AM | #8 | |
Hot Camaro
11-04-2021, 01:18 PM | #9 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Besides the nomenclature get a wrench on it and see if it's tight.
11-04-2021, 02:08 PM | #10 | |
I suspect it's a crush washer. |
11-04-2021, 02:12 PM | #11 |
Drives: Camaro LT1 Join Date: Dec 2020
Part it out
2021 Red Hot LT1
11-04-2021, 02:56 PM | #12 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
That is a plate and frame liquid to liquid, oil cooler. The layers are the plates that give a huge amount of surface area for heat transfer.
Looks like there is an O-ring seal (maybe two), between the heat exchanger and the oil plan. Should be very easy to replace and a cheap part. https://www.gmpartsonline.net/oem-pa...Y4LWdhcw%3D%3D Should be as simple of disconnecting the oil and coolant lines from the exchanger, unbolting it, and replacing the seal. |
11-04-2021, 04:35 PM | #13 | |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Also a good time to change the oil since a lot is going to leak out when you pull that cooler to replace the gasket.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
11-04-2021, 04:44 PM | #14 |
Tags |
camaro ss, camaro ss oil leak, oil leak |
