Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 12-15-2018, 08:49 AM   #1
se7en
Drives: 10 Procharged SS
ECM been changed? Odo reading ---
Is there a way to tell if the ECM in my car isn't the one that came with it from the factory?
Im chasing an issue with my odometer and tripometer not reading anything (---). I was thinking it was the bcm but its been flashed and still no odometer reading.
Any ideas or what else to check for?
10 Camaro: Built 376, LSA Heads, BTR valve train and Stage III Camshaft. F1A 12 Rib-3.75 pulley (17psi), Squash Dual Fuel System with Return (Dual Walbro 450LPH on a Hobbs Switch), Aeromotive regulator, Holley Fuel Rails, ID1300's. RMVB 4L80, 4K Stall, and Trans-brake. 9" IRS, 3.50 gears with a full spool
se7en is offline   Reply With Quote
Old 12-21-2018, 12:41 AM   #2
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man
was everything working and then just quit? a little background would help
ZL1C7 is offline   Reply With Quote
Old 12-24-2018, 09:18 AM   #3
se7en
The car went from an auto to a full manual valve body. Since its been re-tuned to the trans and engine setup, everything works great now except the odometer and tripometer doesn't work, some interior lighting its working and the sunroof isn't working now either. BCM has been flashed and most of the lights on the interior came back but not all. Sunroof still doesn't work.
Everything else works fine tho, which is the confusing part for me.
