Old 03-22-2018, 06:41 AM   #1
Papa Smurf
Cobalt SS Owner to Camaro
Papa Smurf's Avatar
Drives: 2017 Chevy Camaro 2.0L Turbo
Whats RPM's you Manual Trans owners shift at???
I own a Brand New 2017 Chevy Camaro Turbo 4 Banger with the 6-speed manual tranny and wanted to get an overall assumption at what rpm's yall shift at under 'Normal Driving Conditions' (I know hard to say)...but.... I feel the car wanting to shift at a good fuel economy around 3,000 rpm's for each gear. However, 6th Gear feels only comfortable in at like 68mph-70mph on the interstate only lol. Boost kicks in really only at around 3,500 rpm's to about 6,500 rpm's then just drags after that throttle til next shift in Gear.
-17 Chevy Camaro 2.0T-Own
-07 Chevy cobalt ss supercharged-traded
-99 Chevy Cavalier Z28-traded
Papa Smurf is offline   Reply With Quote
Old 03-22-2018, 08:12 AM   #2
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
I find 3k with a little clutch play to get off the line well (have recorded a 5.2 0-60MPH bone stock on the 20" wheels);
Typically I shift between 3 and 4k while cruising and 6th like you mentioned is only good on high speed highways and definitely not for passing...even find myself shifting down into 4th to pass at speed.
Boost is actually hitting hard at 2500rpm+ in these cars (while at WOT at least)
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Old 03-22-2018, 08:49 AM   #3
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
6k rpm for casual city driving.
soloknight6 is offline   Reply With Quote
Old 03-22-2018, 09:45 AM   #4
WhyUMad1LE
Drives: 17 SS 1LE
At low speeds:
around 5mph 1->2
around 10 mph 2->3
around 15 mph 3-4
and for the rest of the time just listen to the engine and you will know when to shift.
Old 03-22-2018, 10:12 AM   #5
Papa Smurf
Papa Smurf's Avatar
yah i agree with you on everything. 6th gear aint for passing. i noticed i do the drop to 5th then 4th as well whe passing. there no boost whe trying to pass in 6th. u just fly in 4th gear, then pop it in 5th then back into 6th. i must must say boost does kick in low for me as well. this car is crazy torque. esspecially at low rpms. i heard the v6 camaro kicks in more at higher rpm's.
Old 03-22-2018, 10:13 AM   #6
Papa Smurf
Papa Smurf's Avatar
Originally Posted by WhyUMad1LE View Post
At low speeds:
around 5mph 1->2
around 10 mph 2->3
around 15 mph 3-4
see its different with the turbo compared to your v8, not that anything is wrong with it. engines are tuned differently and engine are completely different.
Old 03-22-2018, 10:25 AM   #7
geekoffilm
Kjern
geekoffilm's Avatar
Drives: 17 Camaro SS (RIP 7/2/19), 17 A4
Whenever I want, honestly.
geekoffilm is offline   Reply With Quote
Old 03-22-2018, 10:38 AM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
When the green lights in the HUD turn yellow and start to meet.
Old 03-22-2018, 11:36 AM   #9
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
With more torque off the line on the v8, there's more room to play. I start off in 1st around 800-1100 rpms and usually stay between 2k and maybe 4k around town for normal driving. Being mindful of the skip-shift garbage, I tend to stay in first longer. On the highway, I generally pass in 5th, or sometimes 4th if the situation calls for it.
The skip-shift is an idiotic feature and can be somewhat dangerous when it kicks at the worst possible time.....like when making a quick u-turn. Got to get that eliminator.
torqueaddict is offline   Reply With Quote
Old 03-22-2018, 11:53 AM   #10
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
I've been wondering the same for the ss? If I shift right before rev limiter it seems to cut power so i try to shift a little before it. Am I crazy or does this happen to you guys as well?
Old 03-22-2018, 01:01 PM   #11
Dubchitts
Dubchitts's Avatar
Drives: '17 Red hot 2ss, 16 Focus RS
Maintain 6300 if your next to a Prius, whether or not your moving
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC
Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance
Dubchitts is offline   Reply With Quote
Old 03-23-2018, 12:47 PM   #12
Corner carver
Yes, this! Lol
Old 03-23-2018, 12:48 PM   #13
Corner carver
OMG YES!
Old 03-23-2018, 12:51 PM   #14
Corner carver
