Old 12-27-2017, 10:40 PM   #1
Could've_had_a_V8
Drives: 2016 RS V6 M6
Tack Prep for LT V6 non-1LE
Hi everyone,
I'm planning on bringing my LT V6 RS to a performance driving course on track. I've never driven on a track before and I can't seem to find info on whether I need to do anything special to prep my car. I've seen the performance supplement to the owners manual, but that applies to the SS, V6 w/ 1LE, and ZL1. Will I be safe using the stock brakes and stock all season runflats? I want to upgrade the brakes to the 4 piston Brembos. Would that make sense, and if so, would I then have to follow the brake prep guidelines as for the SS? Thanks in advance for any advice!
Could've_had_a_V8 is offline   Reply With Quote
Old 12-27-2017, 10:49 PM   #2
JeromeS13
Drives: 2017 1SS/1LE
If you're starting out, just do a once over on everything. Check your oil, brake fluid, do a visual on your brake pads, check the ENTIRE width of the tire's tread, air pressure, etc. IMO, if it's your first time out, you'll need to concentrate more on basic techniques and procedures, rather than trying to go fast. Just listen to and absorb all of the information that your instructors will be providing.
Old 12-27-2017, 11:15 PM   #3
Could've_had_a_V8
Thanks, Jerome. So will I be going so slowly that I don't need to worry about changing the oil to 5w40 or changing to Dot4 brake fluid?
Old 12-27-2017, 11:20 PM   #4
JeromeS13
With the cool weather right now, I think you'll be fine.
Old 12-28-2017, 12:07 AM   #5
Could've_had_a_V8
Thanks again, Jerome.
Old 12-28-2017, 12:10 AM   #6
JeromeS13
No problem. What group are you running with?
Old 12-28-2017, 01:02 AM   #7
Could've_had_a_V8
I'm planning on participating in the Simraceway performance driving program. I'm going to do both Stage 1 and Stage 2.
Old 12-28-2017, 09:17 AM   #8
Buzzberd6
Buzzberd6's Avatar
Drives: 2LT/1LE, HPCRX, F250(tow vehicle)
Per the GM performance manual, I would recommend adding 1 extra quart of oil to the engine prior to doing your track day. Then draining it out after you're done. I don't know if the standard non-1LE models have the extra oil cooler (doubt it) but I'm pretty sure they all have the same oil capacity.
I've done it each time I've done a track day in my 2LT 1LE, it's not that difficult if you have a floor jack and jack stands. Or ramps could work too.
2017 2LS 1LE
'I feel that life is measured in achievement, not in years alone'
Bruce McLaren
Buzzberd6 is offline   Reply With Quote
Old 12-28-2017, 10:03 AM   #9
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i added dot4 fluid ss lines and got a oil change and rear end flush also and it defiantely helped...also dont know if the v6 has the track pack in the trunk but if it does i would definately put those on or buy some 4 piston brembos for the front and get those also
Old 12-28-2017, 10:15 AM   #10
whiteboyblues2001
whiteboyblues2001's Avatar
It is never a bad idea to upgrade to DOT4 brake fluid before going (don't use DOT5!!). It has a higher boiling point than DOT3. Also, fresh fluid is important too, as brake fluid absorbs moisture from the air, and the boiling point drops as a result.
Just to be sure, take a look at the owner's manual, in the section "Track Events and Competitive Driving", starting on page 197 (for the second printing). Here is a link to the owner's manual:
https://my.chevrolet.com/content/dam...s%20Manual.pdf
Also, the manual recommends changing the differential fluid after your first track event, but I would change mine before and after the first event. The SS's have had a groaning issue, and an early diff fluid change (after the break-in period), helps prevent that. Not sure if the V6 diff has had any issues, but it never hurts to put in some fresh fluid before you go to get out all the break-in material, then change it after, since it will break-in some more, and the diff will get hot.
whiteboyblues2001 is offline   Reply With Quote
Old 12-28-2017, 12:55 PM   #11
Chez
Chez's Avatar
For my first track day I added the 4 pistons, changed fluid and that was about it. As you progress the brake ducting would be worth your time as well. GM sells Ferodo pads for the rear of the V6.
Have fun!
Traded-2017 1LT V6 GMPP Intake, Flowmaster American Thunder axle-back, Vmax Ported throttle body, ZL1/1LE sway bars, V6 1LE Suspension,SEMA grille, Blade spoiler, Apex PS-7 18x10
Chez is offline   Reply With Quote
Old 12-28-2017, 01:28 PM   #12
7stringtheory
Drives: 2017 Camaro 1SS 1LE
Have fun!
I wouldnt spend any money to install the "brake ducting" if what you are referring to are the ducts that come on the 1le. They are actually "tire ducts" because they just come to the wheel well and arent directly fed onto the rotor. Brake ducts are basically useless (at cooling your brakes) unless you feed air directly onto the rotors.
7stringtheory is offline   Reply With Quote
Old 12-28-2017, 02:02 PM   #13
mbar
Drives: 2016 1SS
On your first ever track day you will likely to be slow.
I would replace brake fluid and better brake pads - at least high performance street in not 'light' track pads. The rest should be ok.
When you will get faster you will need better tires, larger brakes and your engine, transmission and rear diff will likely to overheat because they don't have coolers.
Have fun and be safe
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 12-28-2017, 02:04 PM   #14
Chez
Chez's Avatar
I was referring to the duct/deflector setup that SS models have. V6 models other than the 1LE come with neither.
brakes, lt v6, tires, track
