Vararam
Old 05-24-2017, 02:22 AM   #1
Inspiro
Drives: 2012 Camaro SS
L99, Going for cam without LTH
Hi
I'm decided to go for TSP VVT 1.2 cam for my 2012 SS
I contacted TSP, and they replied that the cam should add close to 100 engine hp, but it needs intake and LTH installed before
Intake is no problem, but the LTH will be PITA here in Dubai as I will have to get them removed yearly for testing; as the inspector will not pass anycar with LT, so I wanted to stay under the radar and go for Intake and cam only,
one more thing, the high quality LT with CATs(I don't want my car to be very smelly)will run for like 1400USD ,may be more like 1800 USDif I go for the Kooks green(GESI) cats , not to mention like 250 for overseas shipping to here(which somehow doesn';t justify getting a cheaper header)
How much do you think power I will lose from the cam if I go for intake+ cam only
Thanks in advance
Inspiro is offline   Reply With Quote
Old 05-24-2017, 05:54 AM   #2
Swacer
Drives: 2018 GT350
I'm not sure you'll even get proper airflow without long tubes.
Personally, if you want the power, be willing to do the work. Be willing ot pull the long tubes each year, or find someone who is willing to look the other way.
I guess you could investigate if shorties would work?
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 05-24-2017, 09:11 AM   #3
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
Supercharger?
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 05-24-2017, 09:16 AM   #4
xc_SS/RS
Drives: 2010 Camaro SS/RS
Could you run shorty headers?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-25-2017, 12:11 AM   #5
Inspiro
Shorties will probably pass the test, as long as I keep the CATs, but most of the shorties either look very badly designed with great variance in length and other concerns
While the ones that seem to have good design apparently have issues with the plug wires not to mention they are as pricey as the LTH and then wether they will be good fo rthe cam or not is questionable
Old 05-25-2017, 12:27 AM   #6
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Another option would be turbos... they require the stock manifold to work and you wont have any issues passing inspection.
Not the answer you're looking for unfortunately, but at least you know there are other options, that would not only pass inspection but add WAY more horsepower than a cam ever would.
Dmpsix is offline   Reply With Quote
Old 05-25-2017, 04:42 AM   #7
Inspiro
No chance to pass with aftermarket forced induction, so I wanna stay NA
If I wanna go FI, I'd better start with a ZL1
Old 05-25-2017, 06:07 AM   #8
Swacer
Drives: 2018 GT350
Then it sounds like either enjoy the car as it is, or trade it in for something else
Old 05-25-2017, 06:16 AM   #9
Avenging Orange
Old 05-25-2017, 09:57 AM   #10
Synner
Drives: cars
Just get aftermarket cats and keep the factory manifolds. You'll get the majority of the power that long tubes would have given you and will still pass emissions. Shorty headers I would personally save your money on and not get but you can get some if you really want to.
Synner is offline   Reply With Quote
Old 05-25-2017, 11:01 AM   #11
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
What about z28 manifolds and aftermarket high flow cats
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 05-25-2017, 11:41 AM   #12
xc_SS/RS
I'd check out the Z/28 manifolds like the post above suggests. They are tri-y design and OEM parts should fly through inspection
If you go shorties, pick up some plug wire sleeves or look into ceramic coatings. Both will help with keeping the wires in great condition
They will work with the cam, you just won't realize the full gain. Not sure if you can create a cam to optimize shorty headers, but you could look into that if you wanted
2010 2SS/RS
Old 05-28-2017, 12:30 AM   #13
Inspiro
Thank you for your recommendations, will check the Z28
Old 05-28-2017, 03:05 AM   #14
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
OR.....how about 3.91 gears? OR...how about a torque converter? Neither of those require any modifications to the engine and both will make you markedly faster!
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
