Old 05-08-2017, 08:38 PM   #1
NY Andrew
NY Andrew's Avatar
Drives: 2016 Camaro V6 2LT RS Fully Loaded
Question Underhood buzz/rattle at low speed
For as long as I can remember I think (maybe slightly less apparent in the beginning), I've had this buzzing/rattling, almost quiet "mooing" noise I hear from the drivers side under the hood it seems like when I'm initially accelerating from a stop whether forward or backwards. It would still be in first gear and the RPM's are low (if higher don't think I hear it or if accelerating quicker).
I have no idea what this can be. I do have a subwoofer installed and heard that ANC needs to be disabled or you'll have issued but I don't have any issues unless this maybe is it, but also read that V6 doesn't have ANC so assuming this is irrelevant.. I did come across a bulletin at one point where there may be a noise or disturbance inside the vehicle at low engine speeds between 900–1100 RPM described as a booming, moo, or even a hoot type noise and it will be coming from the vehicle's speaker system, but not sure if this applies to me and all they do is replace the Bose amp apparently..but that does seem similar..either that or I found another bulletin about the fuel line could make a buzzing noise or something but that is heard from the passenger side and I'm pretty sure this is the drivers side.
I've had dealerships look at it in the past I think and one thought it was the hood alignment and that didn't solve it and other recalls they did never fixed like they said would, so what could this be? Anyone have this issue and any possible ideas or resolutions? Wanna see everyone's opinion before I bring this up to the dealer on next visit as well. Thanks!
Borla ATAK w/ Midpipe, VMAX TB, K&N Filter, Subwoofer, Tinted, AFM Disabler, Vitesse Throttle Controller!
ORDERED:08/19/15 DELIVERED:12/09/15
My 2LT Review/Pictures/Mustang Comparison
My 2016 Camaro Bose Subwoofer Install
2016 Camaro V6 Stock to Borla Atak Exhaust Sound
2016 Camaro V6 Resonator & X-Pipe Replace with Midpipe & Borla Atak
NY Andrew is offline   Reply With Quote
Old 05-09-2017, 12:43 PM   #2
steel
steel's Avatar
Drives: 2017 ss camaro 6.2L
could be your high pressure fuel pressure sensor system. Audible at low speeds and idle. Sounds like lifters clicking on the drivers side. This is normal.
steel is offline   Reply With Quote
Old 05-10-2017, 05:32 PM   #3
NY Andrew
NY Andrew's Avatar
Hmm that's interesting haven't heard that one yet, but doesn't really sound like a click sounds more like a bee buzzing.
Old 05-10-2017, 08:36 PM   #4
V8Addict
V8Addict's Avatar
Drives: 2016 2SS
By any chance do you have a strut tower brace installed? I ask cause I notice a slight buzzing sound at times after installing one. Doesn't happen all the time though.
2016 Hyper Blue 2SS, A8, NPP, MRC
V8Addict is offline   Reply With Quote
Old 05-10-2017, 08:53 PM   #5
NY Andrew
NY Andrew's Avatar
Hmm interesting. Don't think that came with the car so no I don't.
Old 05-13-2017, 10:52 AM   #6
JTChief82
JTChief82's Avatar
Drives: 2017 Camaro 2SS/ 2015 Silverado
I have the same noise on mine. It's only at low speeds when first pressing on the gas. Seems to me like the exhaust is doing it or maybe the heat shields under the car.... when I take mine in for first oil change I'm going to bring it up to the dealer.
2017 2SS Camaro, Hyper Blue Metallic, Jet Black, A8, NPP, MRC
JTChief82 is offline   Reply With Quote
Old 05-14-2017, 10:21 AM   #7
NY Andrew
NY Andrew's Avatar
Lemme know if they say anything! Most likely won't catch it. Want an idea of what it is before I bring it back up to my dealer and they try and keep the car for 2 weeks again.
buzz, engine bay, hood, rattle
