09-04-2016, 01:38 AM | #43 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
The PDIM for the 6th gen is USB 2.0. On the 5th gen it was USB 1.1. The development lifecycle on infotainment at GM is slower than a snails pace.
When I had a full 32gb Fit in my 5th gen, it took about 10 mins to index any time the file count changed. If I left it in, it took about 30 seconds to start. With the USB 2.0 interface, it should index on first use within 3 mins and unchanged startups should be ready in under 10 secs. Since this is USB 2.0, it should be able to go all the way up to 2TB on FAT. My concern is in whether this PDIM is slowed down by directory count like the 5th gen was (dumping everything into genre folders was much faster than using artist folders). I would like to keep artist folders if it doesn't cost me a speed hit on boot up. |
09-04-2016, 01:42 AM | #44 |
System folders? You need to install ADB first and root your phone. This will wipe it though, so make sure you have everything backed up with something like Titanium Backup first. Once you've rooted, you can grant permission to read the system and protected app folders when you are connected to your PC. It is not in developer options anymore.
09-04-2016, 01:36 PM | #45 | |
I suppose I need some sort of access package.
09-04-2016, 01:40 PM | #46 | |
The advantage of using USB 3.0 drives with CPL is the building of a big USB goes much faster, assuming of course the drive is plugged into a 3.0 port.
09-04-2016, 03:48 PM | #47 | ||
See above, my 3.0 stick is performing much better than my older 2.0 stick (which was also much smaller in storage size, 2GB vs 32GB for the new 3.0). Go figure.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
09-04-2016, 10:47 PM | #48 | |
But CarPlaylist sull needs to support FAT32 as many cars are stuck on this format. I have the first 2SS Mylink Android Auto flash and it works fine on my car, but that my car has Nav and I have a nice USB music drive, I see little need for it. Is there a later Mylink flash?
09-04-2016, 11:14 PM | #49 | |
Not sure on the 16s. Mine is a 17 and so far no updates for it I've head. Sent from my SAMSUNG-SM-G920A using Tapatalk
09-05-2016, 02:47 AM | #50 |
Ok, you're referring to removal of USB mass storage support, not system encryption.
By default, USB file transfer is handled by MTP, which only grants exclusive access to one item at a time, in this case the OS of the PC. If you're on Win10, you likely cannot have a MTP or PTP device directly accessed by an unsigned application without having it mounted as a drive volume. This would require a virtual host driver that intercepts the connection of MTP/PTP devices and allows you to attach them to a virtual UMS device with a drive letter assigned. Think of it like having an ISO file on your PC. You can't do much with the file, but when you stick it into a virtual drive, you can access the contents with not only the OS but also other applications can see the drive index. I will try formatting with NTFS and sticking a small sample of music on my 64gb Fit to see if it does indeed read NTFS on the '16. Since the PDIM is driven by the headunit and the headunit design didn't change (only the HMI changed between '16 & '17), the USB support of both years should be the same. |
09-10-2016, 08:32 AM | #51 |
Drives: 2016 Camaro 1LT RS Join Date: Aug 2016
09-10-2016, 11:39 AM | #52 | |
09-10-2016, 12:41 PM | #53 | |
I think I will get on and try NTFS. Work has been crazy even spilling over to the weekends.
09-10-2016, 12:42 PM | #54 | |
"Democracy Dies in Darkness" Last edited by Fraxum; 09-10-2016 at 03:53 PM. |
09-14-2016, 07:09 PM | #55 | |
I also am using the 64 gig version of the tiny USB drive. I now have more room in the tiny console compartment! Is the tiny USB a mod for my build thread?
09-15-2016, 09:12 AM | #56 |
