01-21-2018, 10:38 PM | #1 |
Sarcasm loading --------
I was locked out from driving my car today.
today I went to the auto parts store to get some stuff for my silverado, and when I came out the car alarm went off. I didnt think much of it, as it happened 1 time previously a few days ago; but when I got in and pushed the start button and a message on the dash said no transponder. The fob still locked and unlocked the car, so i figured it had enough juice in it to still function correctly but apparently it did not. i went back in the store and bought a pack of 2032 batteries for the fob - which it then started right up.
luckily i was in a place that had the battery, otherwise i would have been walking. now i have a couple extras in the glove box in case it happens again.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
01-21-2018, 11:01 PM | #2 |
Drives: 2017 Red Hot ZL1 M6 Join Date: Jan 2017
You should try the old batteries again. I don't believe your issue was with the batteries. I had a similar issue where the car would not start. I put the transponder in the cup holder and it still would not start. Thirty minutes later it started as though nothing was wrong.
I can't recall, however, if the doors would lock/unlock as my car was in my garage and I was trying to go to work. |
01-21-2018, 11:07 PM | #3 |
Drives: Grandad's C2 L89 Join Date: May 2017
Transponder reboot fix the problem? Battery?
Anyway thanks for the info.
2018 ZL1 1LE sw/PDR
01-22-2018, 12:22 AM | #4 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
If the battery dies, you can place the fob in the cupholder. There's usually a graphic that comes on the center display that shows you where to place it. In the event of a battery failure, that will still allow you to start the car...
01-22-2018, 12:37 AM | #5 |
Good info, Thanks.
2018 ZL1 1LE sw/PDR
01-22-2018, 04:21 AM | #6 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
The question still remains. Why is this happening? It’s the 2nd time I have read this.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
01-22-2018, 05:34 AM | #7 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
It's usually the rear most or driver's side cup holder, check the owner's manual.
I replace my fob batteries at the earliest sign of weakness, i.e. the range on the fob starts to diminish. |
01-22-2018, 08:28 AM | #8 | |
it didnt work. possibly it was the fob re-boot that did it. the car is only 6 months old, it shouldnt be dead after such a short use I would think.
01-22-2018, 11:49 AM | #9 |
Drives: 2018 ZL1 M6 Join Date: Dec 2017
Only six months old I would definitely call the dealer and ask them to look up technical service bulletins that might address this issue there are several out there for some weird stuff going on I don’t recall that this was one of them however
01-22-2018, 12:10 PM | #10 |
Camaro pilot
Drives: 69 Camaro, 2014 ZL1 Join Date: Dec 2015
Myself, I am NOT a fan of push button starting, Having to stick a key in an ignition is just 1 more security check, plus, I wont lose my key if it slides out of my pocket and into the Bermuda triangle.
2014 ZL1 Camaro
1969 Camaro |
01-23-2018, 12:02 AM | #11 |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
