10-09-2023, 03:55 PM | #1 |
Drives: 2010 camaro Join Date: May 2010
L99 camshaft position sensor
Does anyone know the correct part number for the 10-15 l99 camshaft sensor ? 12591720 is what I see pop up but I’m not sure if it’s the correct sensor in the car or not . Been having trouble for quite some time then the engine light came on . Scanned it and that turned out to be the problem. Just trying to find the correct replacement . Any help would be appreciated , thanks
10-12-2023, 01:53 PM | #2 |
Drives: 2010 RS/SS Join Date: Dec 2010
12591720 is the correct part # for that. You may want to diagnose which code you are getting though first, a cam sensor code doesn't always mean the sensor is bad, but hopefully it is something simple like that.
10-12-2023, 02:25 PM | #3 |
This is true. The last time I had an evap code, which my tuner forgot to turn off in the tune, along with an 02 code, the cam sensor came up as well. It wasn't a problem, then when I had a TCM code for the output speed sensor, the cam sensor came up there too. Never once did we have to mess with the cam sensor..
10-12-2023, 02:27 PM | #4 |
Diagnose? What does that mean? If a code happens name a sensor, that can only mean replace that sensor?
10-15-2023, 12:42 PM | #5 |
Thank you guys for your help and advice ! It’s greatly appreciated! I’ll be talking to my tuner this week and we will get to the bottom of it
