dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 05-22-2014, 01:28 PM   #1
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
Supercharger Boost
I understand that one of the benefits of a turbo is that you can adjust the boost, so how does this work with a supercharger? Do you need a tune everytime you want to add boost? And if I am looking towards the IPF Supercharger, how much boost can I run with all stock parts except for a Spec stage 1 clutch good for 350 ft/lbs?
djrasras is offline   Reply With Quote
Old 05-22-2014, 02:03 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Since you have an LLT, the problem won't be you running out of boost, it'll be you running out of fuel. To change the boost on a supercharger you adjust the supercharger pulley. The pulley the ipf kit comes with should be good enough to supply enough boost to the threshold of fuel available
Click Picture for Build Thread
lscamaro is offline   Reply With Quote
Old 05-22-2014, 02:12 PM   #3
djrasras
djrasras's Avatar
So how much boost do you think I will be able to run with the stock fuel pump?
Old 05-22-2014, 03:14 PM   #4
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
On a single turbo 10 psi max on llt.
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 05-22-2014, 10:11 PM   #5
KMPrenger
KMPrenger's Avatar
The IPF kit is supposed to hit 9psi of boost at 7,100 - 7,200 rpms (tune allows it to rev just a bit higher than stock), so yes that is pretty close to the limit I'd say.
Old 05-23-2014, 05:22 AM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Unless of course you are running a Procharger i-1...
Their video even features a Camaro.... (just not a v6...)
http://www.procharger.com/i-1supercharger.shtml
scrming is offline   Reply With Quote
Old 05-29-2014, 08:45 AM   #7
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
If you change the pulley you might have to change the belt? The belt provided is a tight fit from the go. Just something to think about
Sikoriko is offline   Reply With Quote
