11-22-2016, 06:33 PM | #1 |
Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
Paddle shifters
Anyone know how to take the paddle shifters off of the steering wheel? I want to paint them and I don't know how to remove them.
Well............ At least you tried. lol
11-22-2016, 09:39 PM | #2 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
I will tell you next week when my Yellow ones come in per what I saw there is a small screw in the back of them....
11-22-2016, 09:40 PM | #3 |
Retired from Car mfrs....
The wheel has to come off completely, and then you do it from the back
11-22-2016, 09:53 PM | #4 | |
Where did you buy them from? Sent from my iPhone using Tapatalk
11-22-2016, 09:54 PM | #5 | |
Thanks glen! Sent from my iPhone using Tapatalk
11-22-2016, 09:56 PM | #6 |
I used to be Dragoneye...
I am planning to do something similar with mine, so I went searching the internet for a half hour or so...I found this:
http://www.camaro6.com/forums/showthread.php?t=449245 (turn to 2nd page) And a myriad of CTS/ATS threads of the same sort of discussion. It doesn't appear as though the wheel has to come off at all, unless I misread...or something has come up in the meantime? Looks to be pretty easy and straight-forward. Good luck! |
11-23-2016, 09:37 AM | #7 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Wheel doesn't have to come off, however you do have to disassemble most of the wheel to get them out. Airbag first, then the trim around the airbag and the wheel switches, and the lower "SS" trim at the bottom, and then the radio and cruise switches. Once you do that, you can get to the screws that hold the paddles in.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
11-23-2016, 09:42 AM | #8 |
Wish there was a video on how to cause I'm too afraid to mess with all that lol
11-23-2016, 10:00 AM | #9 | ||
Just make sure the battery is disconnected. Don't need any surprises from the airbag. |
11-23-2016, 07:48 PM | #10 |
This is where I found mine....Look at this on eBay:
https://www.ebay.com/itm/272440463645 2016 2017 Chevrolet Camaro Genuine GM Red Automatic Paddle Shift Switch Set |
11-23-2016, 07:55 PM | #11 | |
That's the same one I found but it's too expensive for a piece of plastic Sent from my iPhone using Tapatalk
11-23-2016, 10:07 PM | #12 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
These are just as expensive, hopefully Vitesse will make a set cheaper
Anyway, here are instructions http://www.s2tpp.com/Cam16instructions.html |
11-24-2016, 11:37 PM | #13 | |
04-05-2017, 09:15 PM | #14 |
Drives: 2017 Camaro 2SS, Black/Red Join Date: Mar 2017
Do it, do it...
