Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 08-26-2012, 06:31 PM   #1
Blueclyde
Drives: 2023 ZLE
How Can This Be?
I was reading through the July 12 M/T mag and it had a road test review on the 2013 BMW M5. Their performance numbers showed this 550hp/500 ft lb 4384lb curb weight car running the 1/4 mile in 11.9 @ 120.3 mph. How can a heavier car with 56 ft lbs less torque obtain these numbers? The numbers, to me, do not seem out of line. I just wonder why we have not seen any numbers like this with the ZL1. Seems like the ZL1 should be at worst equal.
Blueclyde is offline   Reply With Quote
Old 08-26-2012, 06:34 PM   #2
MEDISIN
MEDISIN's Avatar
Drives: 2011 CTS-V Sedan
The twin turbo V8 is probably putting down more power than you think. Combine that with an 8-speed DCT and you have your sub 12 sec quarter mile. Only cost $90k.
2012 - Present: 2011 CTS-V Sedan, A6, Airaid, Zmax TB and Tune by R.P.M. = 535 hp/503 lb-ft.
2009 - 2012: 2010 2SS RS IBM M6, MGW Shifter, BMR Trailing Arms/Tunnel Brace, Roto-Fab CAI, VMAX Ported TB, Kooks 6511-Complete (Headers, X-Pipe, Mufflers), dyno tuned by R.P.M. = 415 hp/412 lb-ft.
"Not giving a f*^k is truly the greatest luxury, and no luxury car gives fewer f*^k's than a CTS-V." - Matt Hardigree
MEDISIN is offline   Reply With Quote
Old 08-26-2012, 06:36 PM   #3
oldfriend
Drives: Fiat 500 E
GM also said that the ZL1 had run at 11.9 , so....
oldfriend is offline   Reply With Quote
Old 08-26-2012, 06:40 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it has to do with the "power and torque under the curve". Peak torque with these twin turbo BMWs and MBs is barely above idle and with the ZL1 it is at 4200rpm...huge real world difference. That equates to a few tenths in the 1/4 mile.
Old 08-26-2012, 06:40 PM   #5
CAMAROZL1
Drives: Point A to B Car until ZL1
its all has to do with how the engine was built. The dyno sheet between the BMW V8 and the Chevy V8 must look different although they achieve similar horsepower. For example the torque curve must be different and possibly better in the BMW.
The other MAJOR factor is the transmission.
CAMAROZL1 is offline   Reply With Quote
Old 08-26-2012, 07:32 PM   #6
Rubble2240
Drives: 13 BRM ZL1
Weird also...MT pulled a 12.1 with the Zl1 and nobody is pulling that at the track
Rubble2240 is offline   Reply With Quote
Old 08-26-2012, 07:56 PM   #7
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
Anyone know if MT used corrected numbers?
jimmy5 is offline   Reply With Quote
Old 08-26-2012, 08:03 PM   #8
CAMAROZL1
There's a LOT of variables, which is something that people can't understand. The Chevy 11.9 and Motor Trend's 12.1 were probably under ideal conditions with a PROFESSIONAL driver behind the wheel.
Old 08-27-2012, 05:26 AM   #9
Rubble2240
Drives: 13 BRM ZL1
MT showed the 12.1 on the best drivers car drag race
Old 08-27-2012, 08:54 AM   #10
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
I think most magazines use a correction formula for their exceleration numbers.
sammyv is offline   Reply With Quote
Old 08-27-2012, 10:40 AM   #11
2ndCamaro79
Drives: 2014 V-Sport/ 2015 Escalade
I posted the motor trend vid of the new m5 in the general section awhile back. That car is a beast and a big luxury pig. I get what ur saying OP, and I still believe the zl1 is leaving something on the table. I think any of the V series cars could take the Z, and that should not be either?
2ndCamaro79 is offline   Reply With Quote
Old 08-27-2012, 12:53 PM   #12
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
High performance BMWs are always heavy and fast. Check out the transmission gear ratios compared to our Tremec 6060 ratios. That is an important part of the story. The BMW "M" cars usually have very aggressive gear ratios for the first 2-3 gears to get their cars out of the hole and on down the track. Plus they often have a high redline so that they can pull that better gear ratio a little longer between shifts. Its a deadly combo - better gearing for acceleration and higher redlines to leverage it.
Oh - And it really ticks me off too!
476 rwhp/440 rwtq (sold)
Old 08-27-2012, 01:58 PM   #13
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
What’s Hot:
Responsive, high-revving turbocharged engine
Excellent handling
Able to customize drivetrain/chassis setup to your style
What’s Not:
Tame exterior styling
Slightly numb on-center steering
BMW M5 »
» Overview
» Photos & 360° View
» Specs
» Prices w/Options
2013 BMW M5
Specifications
List price est $100,000
Curb weight est 4288 lb
Wheelbase 116.7 in.
Length 193.3 in.
Width 74.4 in.
Height 57.3 in.
Coefficient of drag 0.33
Engine & Drivetrain
Type alum. block & heads, variable valve timing & lift, dohc 4-valve/cyl twin-turbo longitudinal V-8
Displacement 4395 cc
Bore x stroke 88.3 x 89.0 mm
Compression ratio 10.0:1
Horsepower (SAE) 560 bhp @ 6000–7000 rpm
Weight-to-power ratio 7.66 lb/hp
Torque 502 lb-ft @ 1500–5750 rpm
Redline/limiter 7200/7200 rpm
Fueling direct injection
Recommended fuel premium
Transmission 7-speed dual-clutch automated manual
Chassis & Body
Layout front engine/rear drive
Body/frame unit steel w/aluminum hood, fenders & doors
Brakes, f/r 15.7-in. vented, floating & drilled rotors, 6-piston fixed calipers/15.6-in. vented, floating & drilled rotors, 1-piston sliding calipers
Wheels cast alloy; 19 x 9 f, 19 x 10 r
Tires Michelin Pilot Super Sport; 265/40ZR-19 102Y f, 295/35ZR-19 104Y r
Steering rack & pinion, hydraulic assist
Steering ratio 18.0:1
Suspension, f/r upper & lower control arms, coil springs, elect. adj tube shocks, anti-roll bar/multilink, coil springs, elect. adj tube shocks, anti-roll bar
Just take a look at its torque numbers and how long it last. When Chevy and ford go turbo insteadp of super chargers prepare for things to get silly fast in a hurry. Also having that extra gear helps move all that weight while still maintaining decent mpg's.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 08-27-2012, 05:09 PM   #14
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
LoL..... a sub-12 sec Camaro ZL1 claim by GM........Kinda sounds like a marketing strategy......would you buy a $60,000 Camaro if they told you it runs a 12.65 @ 113mph ??? or would you be seriously more inclined after you saw the GM video about them running a 11.91(or somewhere in that region)......
mr02Z/28 is offline   Reply With Quote
