07-07-2017, 09:45 AM | #29 |
Drive it when you can keep the car moving (no getting stuck in traffic) and don't run the A/C. With no fans blowing the A/C condenser will only add heat to the radiator. Watch the temp gauge. As others have mentioned, if it starts to get hot you can always run the heater! Great summer fun!
07-07-2017, 10:22 AM | #30 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
I've let cars idle for hours at accident scenes in 90-95 degree heat. Never had issues. Of course...NO A/C on when I wasn't in the car either. Still....I agree...You have some issue.
07-07-2017, 11:26 AM | #31 | |
Drives: 2016 1 SS Hyper Blue Metallic Join Date: Feb 2017
07-07-2017, 02:42 PM | #32 | |
376 cubic inches of fun
I hope the dealer can figure out the problem! |
07-07-2017, 05:17 PM | #33 | |
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2) Join Date: Jun 2016
I spent a couple of hours last weekend in Las Vegas in ~110 degree heat, bumper to bumper stop and go traffic on the Strip, AC on max, and it never moved a speck above the same indicated temperature it runs at in the cold of winter. Same with the drive out there. 90+ MPH UP a 17 mile grade with passenger and luggage in 115 degree heat, never even tried to move the needle. Go get the car checked out. Something is wrong. |
07-07-2017, 05:38 PM | #34 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
My 97 Miata and XJ both can idle with AC full blast so yea 2017 Camaro can too
08-04-2017, 09:06 AM | #35 |
well...apparently, the AC fan went. The car is at the dealership now. Had to get the recalls done and waiting for the fan to be delivered. Also having the transmission checked because 1st through 4rd gear are hard shifting.
08-04-2017, 11:38 AM | #36 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Glad they found it OP, my guess was cooling fan died which allowed higher AC pressures which then tripped the AC high pressure switch, the cascade effect then allowed the engine coolant to get too hot which then tripped the high engine idle temps.
While the coolant gauge on the Camaro is a dummy gauge for the most part, once you get over the normal operating range the gauge does become accurate and reflects the actual temps so you know something is wrong. Always watch that gauge, if it gets above the normal 200ish range then the car either needs to be moving to get airflow, heater turned on to try and cool the coolant down or shut off ASAP top avoid warping the heads and or engine damage. |
08-06-2017, 05:36 PM | #37 |
Drives: 2016 2SS Ragtop Garnet Red Join Date: Sep 2016
At least they found the issue for you.
Id be in trouble if I couldnt idle for long periods of times (as would most LEO officers). I sit in my car for hours at a time between site visits. When I test drive vehicles, I start them and turn on the air. If they dont get cold sitting parked, I wont even test drive them. Had a salesman tell me once that I needed to 'drive' it for the air to work - needless to say he didnt sell a car that day.... |
08-08-2017, 09:05 AM | #38 | |
These things are like the silent killer. Most cars have no self-check for radiator fan operation. And many cars have two small fans. They are always electric, often with multiple speeds. Usually by default, turning on the A/C automatically calls both fans to spin at high speed. You might not even notice the fans not working were it not for needing A/C. I have a car with a bad A/C compressor and non-functioning radiator fans. Been driving it for over a year and it never overheats. |
08-08-2017, 09:28 AM | #39 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
Glad you got it fixed! I can't believe some of the responses on this post. Who would think that this was normal? I live in FL and never had the car overheat when parked and running.
08-08-2017, 09:33 AM | #40 |
Drives: 2017 1SS Summit White Join Date: Jan 2016
I'm in Tucson, AZ with average temps of above 101 each day. Zero AC issues when I idle.
Sponsor: SLP Street Legal Performance Instagram: ggShow7ime |
09-13-2017, 06:28 PM | #41 | |
Drives: 2016 Camaro 1SS Join Date: Jan 2016
About a week later I was stuck in a horrible traffic jam. Car started to get hot. I pulled over before it overheated and shut the car off......but not before specifically listening for the fans. They weren't working. Let the car fully cool and drove home. Held a good temp as long as I wasn't in a heavy traffic jam. Dealer confirmed the fans had failed and actually replaced them under my factory bumper to bumper warranty, despite my mods. Good dealer, I know! But now I'm wondering if my fans quit working some time back and caused my AC compressor to fail since the fans are required for proper AC function. Sound about right? And again, the car stayed cool with no fans until I was in a very heavy traffic jam and that's when I first noticed they weren't working at all.
2016 Nightfall Gray Metallic 1SS 6MT, Edelbrock E-force supercharged, Killer Chiller with 3-way bypass, catch can ***FOR SALE, MESSAGE ME IF INTERESTED***
Previous: '12 Mustang GT 6MT (12.47 @ 115.88) '09 G8 GT (11.86 @ 120.47) '05 GTO 6MT (slow, lol) '01 Grand Prix GTP converted to turbo, high 11's |
09-13-2017, 06:47 PM | #42 | |
Drives: Duramax Join Date: May 2017
What happens when someone has to use a recently found China Freight Gift Certificate and now; All he got for Xmas was; 1) A Manifold Set w/vac pump, 2) Broken Cooling Fans and; 3) an A/C that blows hot air. (Sound like a new Country Song) |
Thread Tools | |
