07-05-2017, 09:15 AM | #1 |
Drives: 2016 1 SS Hyper Blue Metallic Join Date: Feb 2017
Overheating
So...my g/f picked me up from work on Monday in her '16 SS. As she was sitting outside for about 30 minutes with the air conditioner on, the air conditioner stopped working (all hot air) and the display said "idle overheating". Obviously a car will overheat when idling in 95 degree weather, for a long a period of time, but it just seemed odd on a NEWER car. So, I popped the hood and waited for the engine to cool down...it was 260+ degrees. Since then the a/c has been acting really odd.
Any thoughts? Comments? |
07-05-2017, 09:45 AM | #2 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
The car should not be overheating in 95F ambient conditions. I suspect the fans are not coming on for some reason.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
07-05-2017, 09:54 AM | #3 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
You should NEVER idle a car that long, especially in that heat, with the air on!!!! EVER!!!!!
Even brand new cars aren't meant to idle that long. Good grief! Now, what SPECIFICALLY is going on with the A/C? "Acting odd" doesn't help troubleshooting. What EXACTLY is the A/C doing now that it didn't do before this? She should take it to the dealer and have them check everything out. Hopefully if there's any problems they'll cover it under warranty. |
07-05-2017, 09:56 AM | #4 | |
Never idle a car with the air on for more than a couple minutes. Even a brand new one. |
07-05-2017, 09:56 AM | #5 | |
07-05-2017, 09:57 AM | #6 |
07-05-2017, 10:17 AM | #7 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
07-05-2017, 10:21 AM | #8 |
They'll idle with the AC on in temps over a 100F and never overheat if the cooling system is working properly.
Something is probably wrong with the car, if they overheated that easily the foilks in AZ would be having issues constantly. |
07-05-2017, 10:42 AM | #9 |
Drives: 2017 2SS, M6, HBM Join Date: May 2017
07-05-2017, 10:50 AM | #10 | |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
The cooling fans should be more than enough to keep the radiator cool in idle conditions, ambient temps of 95 degrees is childsplay in comparison to the operating temperature of an engine (which is well over 100 degrees higher) can't get by the laws of physics, the outside ambient air is much cooler than the engine temperatures, car should stay cool up until a point where the temperatures between the outside air and engine temperature are so close that heat transfer does not happen fast enough to cool the motor, but at over an 100 degrees difference, especially with the help of cooling fans, there should be no issues. Even if it were 115 / 120 we still have right around a 100 degree difference which is more than enough for sufficient heat transfer. Something is definitely wrong, if it can't idle at 95 degrees with the A/C on there's no way these cars would make it in the desert states, or places like Florida or South Texas. |
07-05-2017, 11:07 AM | #11 |
Nuclear Engineer
Drives: 2017 NGM Camaro 1LT Join Date: Feb 2017
New vehicles are tested rigorously in extreme temperatures, certainly much hotter than 95F. The car should not overheat idling by itself in 95F ambient temperature.
People will say oh its not good to idle for that long with the AC on, blah blah. The bottom line is the car should not overheat by itself while idling within design basis temperatures. Go to the dealer and get it checked out- could be a fan issue.
2017 Camaro 1LT - Nightfall Gray Metallic - LTG 2.0L Turbo I4 - 8-Speed Auto - 20" Low Gloss Black Alum. Wheels - Matte Black RS Spoiler - LED Headlamps - Sunroof - Bose Premium Sound System - Smoked Tail lights - Rear Decklid Blackout - Black Bowties - Technology Package
"Sometimes she goes, sometimes she doesn't. She didn't go. That's the way she goes." - Ray |
07-05-2017, 11:15 AM | #12 | |
Something is not operating correctly for the original poster and needs to be fixed.
07-05-2017, 11:29 AM | #13 |
Drives: 08 Accord V6/M6 / 04 Canyon Z71 Join Date: Aug 2008
I used to work at a tier 1 powertrain cooling supplier to the major OEMs. I wasn't on the design or testing side but I remember they had a test that was conducted to verify the vehicle could handle idling in high ambient temperatures. They would drive the vehicle hard in 100°+ ambient temp with the AC on full blast then park it in front of a wall to ensure there was no external air flow and the vehicle would have to be able to idle with the AC for a specific amount of time. I can't remember what the time was, but it had to be more than 20-30 minutes.
For the OP, you should have left it idling with the heater on full blast to help it cool faster. |
07-05-2017, 12:23 PM | #14 |
thanks for all of the input, folks. Since it's not the first or only time the car has sat for a bit with the air on, I figured it was an issue. We'll be making an appointment with the dealer, for sure.
