05-24-2018, 02:37 PM | #1 |
I Carry!
Drives: 2013 CRT ZL1 Join Date: Jul 2011
E85 and 91 Tunes
Don’t have E85 at many places here, for those that don’t run it all the time are you swapping tunes when you do run it? What’s the side effects of not changing the tune when you don’t run E85 and just leave that tune in it. Even with a flex fuel sensor, there’s not a catch all tune for it right? Just wondering as I see folks slapping on E85 sensors and thinking this is good for running it, I know the tune has to be part of that.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540 From Oklahoma, Join us on Facebook https://www.facebook.com/groups/okcamaros/ |
05-24-2018, 04:02 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Just need the sensor and one tune. The ecm allows you to input the stoich and based on the flex sensor input, it will adjust accordingly to maintain the desired lambda and interpolate between tables for mixes in between.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
05-24-2018, 08:51 PM | #3 |
Drives: 2012 ZL1 Join Date: May 2017
Actually your tuner will need to do 2 tunes IF you want to run pump gas and E85. First he will need to write a 91 or 93 tune depending on which you have available I'm your area then completely empty the tank and replace it with E85. You'll want to get the best E85 you can and he will establish a tune for it. Then the FF sensor can adjust to any alcohol level in between. In my area, I have 93 available and it measures 10% alcohol and E85 runs between 60% and about 78%.
05-25-2018, 08:07 AM | #4 |
Drives: 2019 Corvette ZR1 Join Date: May 2017
Having dedicated tunes is a risky thing IMO. When you switch fuels, there is no guarantee that you have completely emptied the old fuel out, so you may still end up with a blend. Also, ethanol content varies at pumps, so you may get E70 from one place, and E85 from somewhere else.
I can get you set up with everything you need to do true flex fuel. The advantage to doing that is you won't have to think about it when you do change fuels. You are correct in that the tune is very important (and required). |
05-25-2018, 10:45 AM | #5 | |
fo'shizZL1
I believe that is what Mr. Steck is saying as well. With the flex sensor and 1 good calibration, you're covered.
05-25-2018, 11:02 AM | #6 | |
05-25-2018, 01:19 PM | #7 | |
I Carry!
05-25-2018, 01:21 PM | #8 | |
I Carry!
05-25-2018, 03:04 PM | #9 |
Drives: 2017 zl1 ,2010 SS /RS L99 Join Date: Sep 2017
E-85 flex fuel tune
I don't know if this helps but I ran a E-85 flex fuel tune . I was able to upload a tune for 93 with flex fuel. Which gave me the ability to run either 85 or 93 without having to upload a tune each time . Only time I had to flash a different tune was if I was at a station that didn't have either 85/93 . Then I was able to flash a 91 tune as well ,so I was able to.run 91 or 85 . 😁
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list ) |
05-25-2018, 03:26 PM | #10 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Didn't you still have a low octane table just in case?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
05-25-2018, 06:10 PM | #11 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
OP, the dsx sensor is not an On OFF, or Yes NO sensor. It detects the amount of ethanol so it might read 10% or 45% or 85% for example, then it reports that to the ECM through a wire so the ECM can read from the ethanol and gas tune tables and adjust accordingly.
05-25-2018, 06:24 PM | #12 |
fo'shizZL1
There is just one tune. After you install the equioment and have your competent tuner write a calibration for you, you are done. As long as you put either 93 or e85 in the tank, or any mix therein, you don't need to mess with the ecm again.
