dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-23-2018, 05:08 PM   #1
lschevelle
Drives: 71 Chevelle 87 camaro
Lsa build help
What's up guys. I know if this the right place for the thread most of you guys seem very knowledgeable about this engine but I want to build a lsa or similar for my chevelle. I want about 800-850hp. My plans is to build the engine to get into the high 600hp range and as nitrous for the rest. Hopefully I can accomplish this by running low boost. What are some options I can look into for my goal? Thanks in advance
Sent from my SM-G955U using Tapatalk
lschevelle is offline   Reply With Quote
Old 05-24-2018, 02:41 PM   #2
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Iron 6.0, forge the bottom end and blow it, you're able to put more PSI through it, cheaper to build and get your HP goals easier and the iron block will last longer, easy to find a good 6.0 iron block too.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 05-24-2018, 03:02 PM   #3
Nicks67camaro
Drives: 1967 LSA Camaro
I you follow this guy in you tube be basically did you what you want. Agree with above migh be cheaper to do the 6.0 iron. I went built LSA for my first gen Camaro based on a lower HP goal.
https://www.youtube.com/user/gtrdude
Nicks67camaro is offline   Reply With Quote
Old 05-24-2018, 03:29 PM   #4
lschevelle
Thank you guys for the replies. Correct me if I'm wrong. There's no real reason to go with the 6.2 over the 6.0 besides weight savings..Correct? What mods will I have to do to the engine and blower for my goal
Old 05-24-2018, 03:47 PM   #5
SamHouseIII
I Carry!
Correct
Old 05-24-2018, 03:49 PM   #6
SamHouseIII
I Carry!
Also not knocking the LSA, but learned and saw first hand how the cylinders barrel out in the center from boost as where the iron block retain the shape better.
Old 05-24-2018, 03:50 PM   #7
camaroarm
Drives: Black and White
I think it migh be cheaper to do the 6.0 iron.
camaroarm is offline   Reply With Quote
