Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 03-11-2018, 09:20 PM   #1
Mystic27
Drives: 2002 camaro ss
Mystery LS1
I have a 2002 slp 35th aneversery ss t tops 6
Basicaly i bought from a gm dealer here
In winnipeg . It has alunimun harmonic
Balancer and a 6.5 quart oil sump. Head are
241. Basically it the fastest car i ever drivin
It will pull hard past 6000 rpm . I am the
Original owner . I have done no mods to it
Any body had any idea what under the hood?
It not a LS1 as it easy out run a LS1 and it vibrates
Like it had a can in it. Plugs would foul if u let it
Idle very long
Mystic27 is offline   Reply With Quote
Old 03-11-2018, 09:24 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Did you confuse LS1 with ZL1? You're in a section where you'll probably receive no help. I'd try a 4th gen section.
Old 03-12-2018, 12:03 AM   #3
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
You can tell buy the casting numbers, if its an ls1. You could also get a cylinder camera and check the pistons to see if they match with an ls1 piston or if they are aftermarket. As far as a cam goes, pull of the timing equipment off and look at the front of the cam, usually aftermarket companies have some type of engraving on their cams.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 03-12-2018, 12:48 AM   #4
Mystic27
Where would i find the casting # ?
There is no # on the block where the
Manual say it belongs?
And thanks a lot for the help. Forums are very
Difficult for 59 year old man
Old 03-12-2018, 01:59 PM   #5
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Pic would help
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 03-12-2018, 07:48 PM   #6
WVracer
WVracer's Avatar
All LS blocks should have the block displacement casted on front and rear of the block on the cylinder bank. Is the throttle body a 3 bolt or 4 bolt?
Old 03-12-2018, 08:47 PM   #7
Mystic27
Will get back to you on that
Old 03-12-2018, 08:48 PM   #8
Mystic27
There is no casting #
Old 03-12-2018, 09:10 PM   #9
Mystic27
The TB is held on with 3 bolts
Old 03-12-2018, 10:11 PM   #10
Mystic27
This is the ss
Old 03-12-2018, 10:12 PM   #11
WVracer
WVracer's Avatar
With 241 heads and a 3 bolt TB, its definitely looking like an LS1.
Old 03-12-2018, 10:13 PM   #12
Mystic27
This is the birth certificate
Old 03-12-2018, 10:15 PM   #13
Mystic27
The car still looks as it was in the picture
Old 03-28-2018, 02:17 PM   #14
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
never seens a LS engine with aluminum balancer. There should be casting on drivers rear of block around where head is. SLP pretty much did bolt ons - exhaust, air intakes, hoods/spoilers and wheels
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
