02-22-2021, 06:02 PM | #1 |
Drives: 2013 Camaro ss 1le Join Date: Apr 2019
lowering a ss 1le?
benefits/regrets , recommendations? should it be done or left stock give me your feedback
02-22-2021, 07:41 PM | #2 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
I did Hotchkiss springs years ago and threw on camber plates along with a larger rear bar and some caster locks. Dialed in a JPSS aggressive street alignment and have been hesitant to do anything else because it's really that good. 100% would do it again.
Sent from my SM-N986U using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-23-2021, 05:06 PM | #3 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I did BMR 1.25” drop springs then switched to Pedder coilovers
02-23-2021, 06:17 PM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I did BMR 1.4. Perfect height.
Benefits: Low life, looks better. In a way better handling. Regrets: No. Does bottom out more often when I hit bump.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
02-23-2021, 07:14 PM | #5 |
Drives: 2015 Camaro SS 1LE, 2014 Chevy SS Join Date: Sep 2020
I'm looking at doing this as well. Some say anything over 1.25" starts to put strain on rear axles. I'm thinking about hotchkis 1" springs. Looking at pics though if its 1 or 1.4 some look lower than others. I've done eibachs and vogtlands in the past on mustangs. Love the look but never get the drop advertised.
02-23-2021, 07:31 PM | #6 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
I had H&R 1.4 drop springs. It rode ok, but wasn't low enough for me. I ended up going with Pedders coilovers and offset diff bushings. It rides awesome.... so smooth and so low.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
02-23-2021, 10:14 PM | #7 |
Drives: 2015 1SS 1LE Join Date: Sep 2015
I have BMR 1" drop and Bilstein B6. No regrets. Rides and handles great.
@Clarkstar - That looks awesome! |
02-24-2021, 12:14 PM | #8 |
02-24-2021, 12:51 PM | #9 |
02-24-2021, 08:34 PM | #10 |
02-26-2021, 06:14 AM | #11 |
Drives: 2014 Ashen Grey Metallic 1LE/1SS/RS Join Date: Jun 2015
BMR 1.4” was the first mod I did 3 months after I bought mine back in June of 2015. The easiest and best mod will always be lowering as far as I’m concerned.
Cold Air Inductions Intake SPEC Stage 1 Clutch BMR 1.4" Springs Borla ATAK Catback Exhaust Kooks 1 7/8" LT Headers w/ HF Cats Last dyno tune was with just intake and catback exhaust did a 401/379. |
05-12-2021, 09:18 AM | #12 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Just converted my 2010 to 1LE suspension with Hotchki springs and Detroit speed rear bar. Amazing difference.
Do you guys notice ABS kicking on/activating more easily? What should be the alignment specs for Street? |
07-02-2021, 08:11 PM | #13 |
Installed bmr 1.4 springs on mine. Realigned car to zero toe front & rear along with .5 degree of negative camber along with retiming the bushings. Car drives great.
07-02-2021, 10:43 PM | #14 | |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
2014 Camaro 1LE SS/RS THE MISTRESS
