Roto-Fab
Old 11-18-2013, 06:07 PM   #1
5genJordan
Drives: 13 Black Camaro 1SS
Need help after header install.!
Hey guys I'm new to the forum and need some advice. What is needed after the fact if I buy headers and had them installed. Kind of looking for a good sound
5genJordan is offline   Reply With Quote
Old 11-18-2013, 06:16 PM   #2
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
You are right it has to be tuned, but it shouldnt run rough like that. I waited 2 months before my car got in for a tune after headers. Sounds to me like you have a leak somewhere. I would check the connections at the cats.
Any leak will cause it to run bad.
45thAnniversary2SS is offline   Reply With Quote
Old 11-18-2013, 06:28 PM   #3
5genJordan
I've retightened every header bolt and even the clamps where the collectors go. I even thought it was bad gas so I ran the car empty and put half a tank with 100 octane.
Old 11-18-2013, 06:29 PM   #4
Biscuitpie
Biscuitpie's Avatar
Drives: '11 Cammed LS3, '14 Scion FRS
You didn't put your spark plugs/O2s back in right or they're broken. I don't see how it could possibly be anything else.
SOLD with a Z06 in the not too distant future: Cammed, boltons, axles, lowered, and more. | 476 WHP
Biscuitpie is offline   Reply With Quote
Old 11-18-2013, 06:33 PM   #5
5genJordan
What could cause the random multiple misfire code? I double checked everything and took it back to get the codes read and it said bank 1 and 2 sensor 2 low voltage and not responding and multiple random misfire.
Old 11-18-2013, 06:47 PM   #6
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Yea. Plugs or leak. Change your gaskets
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 11-18-2013, 06:50 PM   #7
45thAnniversary2SS
How about the connection to exhaust/mid pipes?
Old 11-18-2013, 06:53 PM   #8
5genJordan
I double checked and tightened the connection to the mid pipes again and the same thing. I heard something about the 13's being really sensitive? Could this be true?
Old 11-18-2013, 07:01 PM   #9
45thAnniversary2SS
Damn that's annoying. Wish I could take a look. You have LS3 or L99?
Nothing sensitive about your car. Must have something to do with plugs.
Old 11-18-2013, 07:09 PM   #10
5genJordan
Ls3 motor with 10k miles
Old 11-18-2013, 07:16 PM   #11
jvoisel
Drives: 2010 2SS/RS M6
Did you take the plugs out when you did the headers? I've seen a few people try to leave them in and crack a few.. Check the codes, see which cylinder has an issue and check that plug.
jvoisel is offline   Reply With Quote
Old 11-18-2013, 07:44 PM   #12
rebelyell22
Recheck plugs/wires? IDK if it would do anything but have you disconnected the battery to reset the ECU?
Old 11-18-2013, 08:14 PM   #13
5genJordan
Never installed headers so how would this pertain to that
Old 11-18-2013, 08:14 PM   #14
5genJordan
And yeah I've disconnected the battery multiple times.
