Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 03-20-2012, 09:34 AM   #1
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Fuel injectors, worth upgrading?
Hey guys, I've been seeing that a lot of guys that upgrade their LS3/L99 Supercharged cars they take the supplied injectors and replace them with quality high end versions.
So I was wondering if replacing the injectors on the ZL-1 would either increase (slightly) HP or is it just a better and more efficiant way of providing fuel to the engine?
armysig is offline   Reply With Quote
Old 03-20-2012, 09:42 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
IIRC - LSA enjoys a similar dual-mode (so-to-speak) fuel system, similar to LS9 because the obvious fuel requirements of the SC. We know they're upgraded above LS3-specs', but something that seems new to 'V LSAs, is it seems, perhaps, the injectors may have been changed.
In a current article in GMHTP, ADM was adding their Stage I 'V-upgrade (along with the customer's air cleaner upgrades) and in the final tuning, Andy noted that he was expecting the injectors to reach their repsective limits, as I suppose they have on earlier V' mods', but this brand new 2012 V' didn't seem to approach the current car's limits.
The car ended up around 590 RWHP, and it seems like Andy, perhaps, though there may be unannouced '12 changes for LSA, and at least in the Caddy', it seems there's a chance that either they had a ringer for this article, or LSA-V's might be making a little more power (perhaps because ZL1 changes might carry over to V', somewhat).
Anyways - unless you are seriously increasing fuel requirements (i.e. adding a top-end kit or more boost), adding fuel may not necessarily be worth the expense, especially if you don't intend on any of the above. I guess we're just going to have to wait :(
'20 ZL1 Black "Fury"
Old 03-22-2012, 12:48 AM   #3
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
On the V's with an Upper Pulley and CAI the stock injectors were about maxed out. Most people who have modded their cars with both pulleys changed are swapping injectors. I had headers, CAI and a tune and my stock injectors were hitting close to 100% Duty Cycle. I am not sure if the stock injectors in the ZL1 are same or not.
I am going with the ID850 injectors as they should be good for almost anything I want to do and good for E85 also. I believe we are seeing the stock pumps good up to 650-700rwhp - past that you can run a Boost-a-pump.
Speed74SS is offline   Reply With Quote
Old 03-22-2012, 10:13 AM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Thanks, Speed'
I just wanted to be clear that I was only commenting on the '12 that ADM tested for GTHMP. From the article, Andy reflected exactly what Speed74SS said about the injectors max'ing out. The '12 didn't, which surprised Andy, so maybe ZL1 and CTS-V are sharing more components than GM's announced. The more the better
Old 03-22-2012, 09:29 PM   #5
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
Replacing injectors as a standalone mod does not increase hp. It is a supporting mod required when increasing engine airflow which increases injector duty cycle to the point of being static at WOT. As a result the ECM cannot supply enough fuel for accurate air fuel ratio. Increasing injector size simply allows for better and more precise fuel metering.
DrkPhx is offline   Reply With Quote
Old 03-24-2012, 08:01 AM   #6
Speed74SS
Speed74SS's Avatar
Thanks, Speed'
Yes - that is very interesting. You would think GM would share the specs if they were making it better. Again, the ZL1 is making waves as an amazing car and we are all reaping the benefits
Old 11-27-2014, 05:26 PM   #7
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC
Has anyone seen a DIY thread for an injector change out on a ZL1
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
Old 11-27-2014, 07:07 PM   #8
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
http://www.camaro5.com/forums/showth...71#post7505171
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 12-05-2014, 11:04 AM   #9
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
we usually always move up to 80lb injectors whenever going a pulley swap on the LSA, especially when upgrading the upper and lower pulleys to ensure proper fueling.
Nick
Lethal Racing is offline   Reply With Quote
Old 12-05-2014, 11:10 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
There is no advantage to changing injectors unless they are accompanied by more air flow.
Anything above 10% crank pulley requires larger injectors to match the fuel with the added air.
I recommend and use Injector Dynamics ID-850 as the go to injector set from 600 up to 1000 Horsepower on gasoline.
An injector change must also include a custom tune.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-05-2014, 02:05 PM   #11
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
My 2013 ZL1 definitely didn't receive better injectors, if in fact the Caddy got the upgrade. Just with headers, intake & tune it was obvious I needed them before I did any other power adders.
BaylorCamaro is offline   Reply With Quote
Old 12-05-2014, 10:16 PM   #12
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
I've hit in the upper 90's for percent duty cycle on my stock injectors. I only have headers, a Rotofab, and a tune. I don't like to see over 85-90%. I'll be putting some FIC injectors in. I'll do 850cc injectors if I decide to keep it gasoline or 1200-1300cc injectors if I decide to do a Dave Steck flex fuel setup.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 12-06-2014, 08:03 AM   #13
JANNETTYRACING
That is probably in Cat over temp protection mode which is normal.
If you turn off COT they won't go that high.
Ted.
Old 12-06-2014, 09:11 AM   #14
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Ted.
COT is off.
97% in 3rd gear this morning and 93% in 4th.
JDP Motorsports' 2010+ Camaro SS Fuel Line Retrofit DIY JDP Tech Camaro DIY & HOW-TO instructions & discussions 27 08-17-2017 12:31 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-17-2012 11:24 PM
Do you really know SIDI?(spark ignition direct injection) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 01-31-2012 06:18 PM
Check engine light on Boricua Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-28-2010 01:12 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
