03-04-2024, 06:58 AM | #29 |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
You can remove the speaker from the AirTags so it won’t make a sound. I did that and hid it where it will be harder to find.
03-04-2024, 10:24 AM | #30 |
Drives: 2022 SS 1LE Join Date: Aug 2023
An AirTag still has to be removed and charged periodically, right? That was another drawback for me.
03-08-2024, 10:23 AM | #31 |
Drives: Chevrolet Camaro 2LT RS V6 3.6L Join Date: Jan 2024
I finaly got it working. I used the following:
1. Rechargeable GPS Tracker (no case needed) Brand I chose is Optimus 3.0 at $19.95 a month. 2. 12V Charging Socket with inline fuse 3. 12V Charger USB adapter WITH voltage indicator 4. Blue color "T" /blade & splice connector 5. Needle Nose pliers for compressing splice connector 6. 10mm socket with 6" extension for fuse box nut to ground wire install 7. Large pliers for compressing blade connector to red wire on 12V socket 8. Deluxe Wire strippers to strip red wire on 12V socket
2017 Camaro RS V6 3.6L
03-08-2024, 10:38 AM | #32 |
Here's the parts I bought:
Optimus 3.0 Wireless GPS Tracker https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Self adjusting easy to use wire strippers https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 12V Socket Car Adapter https://www.amazon.com/dp/B07CQMQL9L...t_details&th=1 T-Splice Connectors https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 12V USB adapter https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
04-12-2024, 11:22 PM | #33 |
Drives: 2016 Chevrolet Camaro 2SS Join Date: Feb 2024
Just have mine to the battery for now, but am moving when i install subs and amp etc. Probably come off my battery with sub wire and shrink wrap it to sorta hide it. But they will think its for amp power on... I ran wires to side of trunk and put it on the rear speaker deck over the sheetmetal but benieth the trim panel.. great reception.
04-13-2024, 01:52 PM | #34 | |
Drives: '23 LT1 A10 Join Date: Oct 2015
24 LT1 M6 Sharkskin Metallic
04-26-2024, 05:44 AM | #35 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
I have the Gen5 DIY radar detector line, and I bought it with pigtails for a dash cam, so I just made another Y off that line, and ran that down to a GPS that's well hidden.
Also went with the Optimus, and I think it's $10 / mo. Works very well. Finally got my Igla installed this week so that's a HUGE sigh of relief. They want my car, gonna have to tow it.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
