Roto-Fab
Old 04-01-2017, 11:25 AM   #1
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
Kooks high flow cat dented
Bought a set of used headers. The coupling end of the cats are both dented in exactly the same. Do you think I can reform them by attaching them to the headers and tightening the bolts until they are returned to their original shape.
StingrayblueSS is offline   Reply With Quote
Old 04-01-2017, 01:56 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
An idea. I would take a ball peen hammer and attempt to make it true again. Then bolt them up and tighten. How do the header side connections look?
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come.
Black_SS10 is offline   Reply With Quote
Old 04-01-2017, 02:16 PM   #3
Synner
Drives: cars
Will need to be beaten out some or it won't even set in the socket to tighten it.
Synner is offline   Reply With Quote
Old 04-01-2017, 02:44 PM   #4
StingrayblueSS
Thanks guy, the header tips look good. I don't know what would have happened to the cats.
Old 04-01-2017, 03:03 PM   #5
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Could have been dropped to cause the dent . Simple fix with a hammer .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 04-01-2017, 03:13 PM   #6
StingrayblueSS
True, but both cats in the same location seems strange.
Old 04-03-2017, 01:58 AM   #7
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
couldn't a hammer loosen the insides of the cat. Id take it to a muffler shop and have them reshape it.
Old 04-03-2017, 07:13 AM   #8
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Most likely a speed bump on a lowered car imo
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 04-03-2017, 07:32 AM   #9
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Use a crescent wrench and roll it that way.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-03-2017, 08:51 AM   #10
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Do you have a torch? Heat it blazing red hot, tighten it down to the header ball. If it's hot enough, it'll shape itself. Hammering it may not be so great on the guts, and may just cause an irregular dented up shape tough to seal. Wait till its cherry red in that area, and use hardened bolts and nuts, should draw it together.
Russell James is offline   Reply With Quote
Old 04-03-2017, 09:14 AM   #11
StingrayblueSS
I went ahead and reshaped them with a hammer. Hopefully it won't leak.
