TireRack
Old 03-30-2017, 01:20 PM   #1
MSull16
MSull16's Avatar
Drives: '10 Camaro SS LS3
Upgrading Throttle body worth it?
My car isnt FI, and I heard typically those folks see gains but not us naturally aspirated guys. Im running out of upgrades before Im left with deciding on cam/heads vs. a blower. If its worth it I may snag a 102mm or save up for 3.91 gears for the torque. Thoughts?
B&G 1.5"/1.4" Drop Springs, FR41 20" Rims, ACS T4 Splitter, RF Sound System, Rotofab CAI, SW Catback Exhaust, American Racing 1 7/8 LT Headers w/ Off-road pipes and Tune by JWC Performance
MSull16 is offline   Reply With Quote
Old 03-30-2017, 01:32 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
102mm is too big for stock intake manifold, 95mm is perfect for stock manifold and that even requires slight porting on the manifold to get a smooth transition
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 03-30-2017, 03:22 PM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
3.91 gears will make city driving alot more fun...Have you thought about a ported TB as an option as well?
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 03-30-2017, 03:28 PM   #4
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Have you done an Electric Water Pump, E85, Ported LS3 Intake?
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 03-30-2017, 03:40 PM   #5
jrhagen
Drives: Camaro
No
jrhagen is offline   Reply With Quote
Old 03-30-2017, 04:07 PM   #6
MSull16
MSull16's Avatar
I thought it wasnt safe to run E85? Is there a kit that makes it safe?
Old 03-30-2017, 04:41 PM   #7
lazerlemonta
Drives: 2010 C6 1LT
I run DMS kit with hp tuners adding flex fuel tables
http://www.dedicatedmotorsports.com/Default.asp
Best MPH 134.82
Old 03-30-2017, 04:52 PM   #8
KonigWolf
Drives: 2016 2SS A8
I'm also considering a throttle body and E85. I need to contact Bo White for his opinion on. His TB vs. say BBK 95mm..
What size injectors and fuel pump you running?
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA
KonigWolf is offline   Reply With Quote
Old 03-30-2017, 07:46 PM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Get in touch with Bo White and get one of his ported throttle bodies. It doesn't make as much of a difference on throttle response on a LS3 as it does on a L99, but it does still make a difference. For a L99 it should almost be a mandatory upgrade as those things in stock fashion suck for throttle response.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 03-30-2017, 09:58 PM   #10
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Port it. There is a bunch of material to remove.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 03-30-2017, 10:04 PM   #11
davidscamaro
BBK 95mm and port your own manifold the 2-3mm at the snout for maximum power gain from PTB mod
Old 03-30-2017, 10:07 PM   #12
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Port the stock TB.
Bo White is offline   Reply With Quote
