08-09-2017, 06:42 PM | #1 |
Drives: currently shopping Join Date: Aug 2017
How to tell if a car has mag ride?
I've been eyeing sixth gens on a dealer auction site and will proxy bid on one tomorrow. Is there anyway to tell in pics or from a VIN number that a car has mag ride?
08-09-2017, 07:30 PM | #2 |
Drives: BVM 1SS Join Date: Oct 2016
The only way I know of if a car has Magnetic ride is if you can manually change the suspension settings within the settings menus.
08-09-2017, 08:29 PM | #3 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
RPO code 55 if you have a pic of the build sheet. Or a close up of the lower control arm.
08-09-2017, 08:35 PM | #4 |
I have also heard you can call a dealer parts department with the VIN and they might check it for you. I also did some experimenting and at Gmparts you can enter the VIN number and you could call them and see what shock you need. If it's a variable then you know its mag ride.
08-09-2017, 09:19 PM | #5 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Check visually
You will see the little sensor and the little arm on each suspension.... |
08-09-2017, 09:28 PM | #6 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
what biscuit said, or just see if you can change the suspension settings on the dash. If you cant, no mag ride.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
08-09-2017, 09:29 PM | #7 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
He doesn't have access to the car.
Kindness and compassion #OthersFirst |
08-10-2017, 04:28 AM | #8 |
Drives: 2017 Red Hot 2LT RS Join Date: Jul 2013
If you can view or get a picture of the RPO codes from the decal in the trunk, it will have RPO F55. Else, from the VIN, any GM dealer service department can run a VIS report and it will give you a listing of all standard and option content that came on the car.
03-23-2018, 10:18 AM | #9 |
2nd mosted hated in NM
Drives: Tuned for her Pleasure Join Date: Aug 2012
it will have a RPO code of F55
