07-15-2010, 08:39 PM | #1 |
BILLYSPEED
Drives: 2016 black camaro SS Join Date: May 2009
REAR WHEEL MAX SIZE
what would be the max sizi tires i could put on the rear of my camaro 1ss?
thanks for all info...
2010 camaro ss sold
2011 camaro 2ss/rs convertable sold 2015 ZL1 sold 2016 camaro SS sold |
07-15-2010, 09:51 PM | #2 |
Drives: Shopping Join Date: Feb 2010
Assuming you mean width, theres plenty of guys running 315 width. If you mean height, theres a 2010 Camaro on 28" rimz on Miami craigslist LOL
______________________
2010 2SS RS Auto - Black 1970 Chevelle SS 396 |
07-16-2010, 07:48 AM | #3 |
BILLYSPEED
thanks.. yeah i saw that post... that is just wrong !!
2010 camaro ss sold
07-16-2010, 07:51 AM | #4 |
305's fit perfectly.
07-16-2010, 09:43 AM | #5 |
Drives: 2010 Summit White Camaro 1SS Join Date: Oct 2009
315's fit amazing lol (just got them!)
Engine: 402whp & 394TQ Hp-tuned, Kooks 1 7/8" catted headers, 3" Kooks Cat-back Exhaust, Roto-fab Intake (Summit white), Skip shift Eliminator.
Exterior: Blacked-out Tail lights / Reverse lights / Side Markers / F & R Bowties, Stealth turn signal bulbs, AAC Blue Dome and Footwell lights. Wheels/Tires/Suspension: ForgedStar F14 Rims (semi gloss) 20x9.5 & 20x11, Nitto NT05's 275/40/20 & 315/35/20, Pfadt Lowering Springs. ICE: Audison LRx 5.1k Amp, 2 Hertz Hi-Energy 250w Componet Speakers, 2 Bravox Audio CF 260w Coaxial speakers, 12" Hertz Hi-Energy 1200W Subwoofer, ******** Box and Amp Rack. |
07-17-2010, 07:40 AM | #6 |
Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Max width tire is 315 wide. Fits perfectly, even on lowered cars. Of course, you will need a 10.5 to 11.0 wide wheel to accommodate that tire width properly. And an experienced wheel source to get the proper fitment
Fquick.com/NineBall
07-17-2010, 08:30 AM | #7 |
Drives: 10 Procharged SS Join Date: Oct 2009
I wouldn't put bigger than a 305 on stock rim's. If you plan on ordering aftermarket (see Tony) and get a 10.5 or 11 inch then slap on 315's.
07-17-2010, 12:11 PM | #8 | |
Drives: 1SS/RS/M6-White/Beige Join Date: Jul 2009
bws_82, not intending to be offensive, however, I think you are pushing it to far recommend putting a 305 tire on the stock wheels. The recommended ranges for the 9 inch wheel shows a 295 tire as the largest tire for a 9 inch wheel, I would not recommend anything larger for a tire on the stock wheels. Here are the recommendations: 295 tires: 9 to 11 305 tires: 9.5 to 11.5 315 tires: 10 to 12 I would recommend staying mid to wide side of the width range when buying wheels for the tire size you want to use.
07-17-2010, 03:22 PM | #9 |
Drives: 2010 camaro Join Date: Aug 2009
i assume you would need correct offset of 35mm on rear to fit a 315? you would not say a wheel with offset of 25mm can fit under fender?
07-17-2010, 07:01 PM | #10 | |
The stock rear wheel has a +40 mm offset, if you use a new wheel with same offset and the 315 tire this combination will stick out an additional 0.8 from stock position. If you go to a +35mm offset it will stick out an additional 1.0 inch, +30mm -> 1.2 inch. Pick up the trend? I have the 305 tire and am using a +40mm offset and seeing 0.6 inches from stock - the tires are still within the wheel well - this set up works great for me. I think +40mm would work fine for me as well for the 315 tires. The front wheel/tire combination seems more sensitive to offset however I think for most wheel/tire combinations something in the range of +30mm would be the target offset.
07-18-2010, 07:03 AM | #11 |
Be careful when discussing offsets. Offset measurements must be included and referenced to a specific wheel width, or the information means nothing. Both are linked directly. A 20x9 wheel and a 20x10 wheel with the same offset do not fit anything alike.
Fquick.com/NineBall
07-18-2010, 08:46 AM | #12 |
Drives: the 2nd amendment home Join Date: May 2008
-- Benjamin Franklin |
07-18-2010, 02:53 PM | #13 |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
I bought my wheels from Nine Ball. I have 11" wide rims and 315 wide tires on the back. My car is lowered and they look and fit great!
07-18-2010, 03:08 PM | #14 | |
Please check into this a little bit more. Regards.
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
2010 Camaro SS Blue in Syracuse NY $32690 | Mitsubishi in Syracuse | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 12-31-2009 02:44 PM |
Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 12:06 AM |
