08-23-2015, 12:36 AM | #1 |
Drives: 2015 Camaro 2SS 1LE Join Date: Apr 2015
2015 SS upgrades Brakes/Suspension questions/options
So, I have had my 2015 SS for 3 months and absolutely love it. It's got 7,000 miles on it already (and isn't my DD anymore)
I would like to slowly start modding the car to improve some things as I'd like to add some power to the mix. So my questions would be : Brake wise, where would the best bang for my buck be? Is upgrading to the 6 piston front, 4 piston rear from the CTS-V worth it? If not, what is then my best options in regards to : Rotors/Pads ? Lines ? Brake ducts? Fluid? Same generic question suspension wise, where is my best bang for my buck? Coilovers? Sway bars? Strut tower bar? Any other suspensions upgrades I should look at?
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP 2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold 2018 M2 Exec - Current |
08-23-2015, 08:48 AM | #2 |
Drives: 2011 SS Join Date: Nov 2011
I WILL MAKE THIS SIMPLE...MAY POST ON HERE ABUT THIS. GET THE FRONT CTSV BRAKES ONLY. THEY DO MST OF THE WORK AND THE REARS AND REALLY THE SAME ON BOTH MODELS. UNLESS YOUR A MANIAC ROAD RACER DOT 4 BRAKE FLUID IS GOOD. GET STAINLESS LINES ON ALL 4, MAJOR IMPROVEMENT FEEL. BRAKE DUCTS ARE JUST THERE FOR AGAIN THE MOST EXTREME. GET PADS THAT ARE SUITED FOR YOUR REAL EXPECTATIONS.....THE BETTER THE PAD THE WORST IS THE NOISE. AND I MEAN SCHOOL BUS GRINDING NOISE. WELL I HOPE THAT HELPS.
08-23-2015, 09:01 AM | #3 | |
Drives: 2000 Camaro SS Join Date: Feb 2010
08-23-2015, 12:45 PM | #4 | |
I have already experienced brake fade when driving somewhat hard, so I figure when I get ready to increase power I need to think about braking. At the very least I know I need to do better fluid, and stainless steel lines. But I need to weigh the pros/cons of putting bigger brakes with pads/rotors or just doing pads/rotors.
08-23-2015, 04:02 PM | #5 | ||
08-24-2015, 12:49 AM | #6 |
I just did the ctsv brake kit (stage 2 from JDP) and even though I don't track my car (yet), I smile hard when braking nowadays
08-24-2015, 04:19 PM | #7 | |
08-24-2015, 04:55 PM | #8 |
As I mentioned in my answers above, the overall braking force is actually almost the exact same as the 4 pot Brembos. Any additional stopping power realized with the 6 pots is from better pads. Cooling is what you are getting with the 6 pots. Of course, you can spend your money however you like but it is a lot to spend when you could achieve the same street performance for 1/10th the price.
08-24-2015, 06:12 PM | #9 |
I did all 4 because a friend wanted to buy the ones off my car for his zl6 (cool name) I also read somewhere on here that these brakes were tested and, as my friend chase here said, there was no big difference in stopping power. I also did stainless steel lines so maybe thats what im feeling the most.
08-24-2015, 08:51 PM | #10 | |
