12-26-2013, 09:41 PM | #1 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
DIY:V6 Brakes to 4 Piston Brembo Calipers
Hey guys here is a DIY to add SS brembos to a v6
#1 jack your car up and don't forget to use jack stands!!!! 2 Remove wheels 3 Remove bolt that holds brake line to the caliper (green paint is on it in the pic) 4 Remove U clip where the rubber brake line goes into the plastic line. (see pic 3) 5 Remove 10mm bolt hat holds brake line to the strut assembly (pic 4) |
12-26-2013, 09:45 PM | #2 |
Step 6! Remove 10mm Bolt from brake line hold assembly (below pic)
---7! Place ratchet on top of the line and unscrew the line from the rubber part of the line. (pic 2) Your Stock line is removed! I replaced mine with Goodridge stainless steal lines |
12-26-2013, 09:52 PM | #3 |
Bolt in your new line using the steps to remove the stock line!
Next is to remove the caliper. It is held in with 2 bolts! Remove the 2 bolts and the caliper will be removed! Next slide your rotor off....there will be a star screw holding it in! Your rotor is off and you are down to the wheel hub! I always like to clean the rust off the hub using a dremel. |
12-26-2013, 09:59 PM | #4 |
Install your new brake rotor!
Install new caliper Tighten 2 bolts and use blue loctite! Attach new brake line to new caliper make sure everything is tight and not loose Bleed brake system.......there are 2 bleeding valves on the calipers...bleed them until you have all of the air out of the system and you do not see any bubbles! Install wheel Torque wheel to 100foot lbs Go test brakes and brake in your new pads! |
12-26-2013, 11:08 PM | #5 |
Drives: 2014 Blue Ray Met. Camaro 1SS Vert Join Date: Feb 2012
Looks great!! Done mine a mouth ago. Love 'em
12-27-2013, 02:53 PM | #6 |
Drives: Black Join Date: Jan 2010
The caliper bolts are on tight! I needed long breaker bar.
12-28-2013, 11:34 PM | #7 |
Drives: '12 2LT Convertible Join Date: Mar 2012
Caliper bolts are torque to yield. You need to torque them to a specific value then add 90 degrees.
The brake lines also have specific torque requirements as well. Here are the torque settings for the front brakes (from ZL1 brake upgrade installation instructions): Front rotor screw (torx): 10 NM [ 89 LB IN ] <- inches, not feet Caliper bolts: 40 NM [ 30 LB FT ] + 90 degrees Brake line to Caliper: 40 NM [ 30 LB FT ] Brake line to Interior brake line: 16 NM [ 12 LB FT ]
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
12-29-2013, 08:09 PM | #8 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Nice write up for those who have not done this mode. I did mine almost 4 years ago I love mine.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
12-29-2013, 10:46 PM | #9 |
Its a nice and a not too expensive mod!
02-11-2014, 10:05 PM | #10 |
Drives: 2015 ZL1 Join Date: Oct 2010
What about the rear brakes? I'm picking up a set of red 1LE Brembos and have read that the V6 dust shield need to be replaced with V8 dust shields on the rear. Anything else to be concerned about? Thanks for the write up as it answered a lot of questions for me!
02-11-2014, 10:14 PM | #11 |
You can change them but a pain to do. Most of us just trimmed the V6 shields and painted the raw edges with black paint. Other than that fits and works great!
02-11-2014, 10:21 PM | #12 |
Here are some spec charts for the SS.
02-14-2014, 09:09 AM | #13 | |
#TeamBeckyD
#TeamBeckyD
02-14-2014, 09:10 AM | #14 |
#TeamBeckyD
My other suggestion if you are going to do this replace the OEM pads with Hawks Pads the brake dust will kill ya.
#TeamBeckyD
