11-18-2013, 02:51 PM | #1 |
Drives: 2014 Camaro 1SS 1LE Join Date: Aug 2013
Actual torque numbers for the 1LE?
With the ungraded 3.91 rear and M6 trans., I am hearing the torque multiplier is increased by 13%. This would put the actual torque numbers for the 1LE at 475 tq. Is this accurate?
11-18-2013, 03:14 PM | #2 |
Drives: 68 Camaro--2009 Corvette Join Date: Oct 2013
13% over what? 1LE has a trans with different ratios than a SS. SS has a different rear end ratio so maybe the 13% increase is if you go from stock SS ratio in a SS to a 3.91 ratio in a SS?
11-18-2013, 03:25 PM | #3 |
11-18-2013, 03:52 PM | #4 |
Drives: 2014 1LE Join Date: Sep 2013
That's not how gearing works. The engine stays at the same rating.
11-18-2013, 04:11 PM | #5 |
11-18-2013, 04:20 PM | #6 |
Drives: 2011 ss Join Date: May 2013
11-18-2013, 04:53 PM | #7 |
Angry by Nature
Drives: 13' Camaro 1SS/RS/1LE/NPP 1 of 76 Join Date: Aug 2013
2013 CHEVROLET CAMARO 1SS/RS/1LE/NPP 1 OF 76 Roto Fab CAI 1LE BADGES |
11-18-2013, 04:57 PM | #8 |
Drives: 2013 Camaro 2SS RS LS3 Join Date: Feb 2011
-2013 Summit White over Inferno Orange 2SS RS- -2014 White Diamond Silverado Z71 Crew Cab Short Box- |
11-18-2013, 08:16 PM | #9 |
I used to be Dragoneye...
Physical (as in physics) torque is, indeed, multiplied as they claim...that's why the car feels quicker...and likely is a bit quicker...the change in gearing results in an increase in mechanical advantage.
But the engine is not producing any more power...and if I understand it correctly - that's what dynamometers are calibrated to read. For reference: here's the ratios...and the overall ratios (once through the rear end)...note that the real difference is in how the gears are spaced much closer, and more evenly 2-5. That's what makes the 1LE transmission so nice on a track. |
11-18-2013, 08:58 PM | #10 |
Drives: 2013 1LE RS 1SS Join Date: Apr 2009
ALSO REMEMBER OVERALL TIRE HEIGHT IS ALSO DIFFERENT
11-18-2013, 09:05 PM | #11 |
Angry by Nature
That's why dyno testing is done in 4th gear. One to one gearing. One rpm input = one rpm output. No tourque multiplication.
11-18-2013, 09:09 PM | #12 |
Moderator
Basically, you can't mathematically make a claim on horsepower or torque based on something that isn't measured in that equation. It's also a bad habit to add horsepower claims from parts to your stock vehicle. Headers will not get you 30+ hp on top of 15+ hp for your exhaust and 5+ hp for your intake. Don't add horsepower based on what you've done to your car. Get real numbers with a dyno, but more importantly take it to the track! That's where you'll see the real gains.
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR RESPECT ALL CARS. LOVE YOUR OWN. warn 145:159 ban |
11-18-2013, 09:28 PM | #13 |
Yes. By about 1/4 of an inch overall.
EDIT: I'm wrong...¾ inch. |
11-18-2013, 09:38 PM | #14 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
It is closer to just over 3/4" OD delta
285/35/20= 27.85" OD 275/40/20= 28.66" OD Matt
