Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 11-10-2016, 09:33 PM   #1
HRD_WRK
HARD WORKING PATRIOT
HRD_WRK's Avatar
Drives: 2011 CAMARO 2SS RS-AUTO
resolved.
Resolved.
HRD_WRK is offline   Reply With Quote
Old 11-11-2016, 10:40 AM   #2
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Text me.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 11-20-2016, 01:19 PM   #3
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
Any update on this? Trying to find the part numbers for all if these.
SSjosh is offline   Reply With Quote
Old 11-22-2016, 07:02 AM   #4
dentnshell
dentnshell's Avatar
Drives: Black 2014 2SS
I just did a zl1 differential swap on my 2014 SS.
The original bolts were the torx end style... The ZL1 bolts (larger bolts) were Hex style, according the the ZL1 swap instructions.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.)
dentnshell is offline   Reply With Quote
Old 11-25-2016, 11:43 PM   #5
SSjosh
SSjosh's Avatar
Drives: 2011 SS 6MT
I got my bolts in for my 2011. They were also not torx.
Old 11-26-2016, 01:06 AM   #6
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Hell I'm running Mercedes bolts in mine lol.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 03-27-2017, 07:35 AM   #7
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
I have a '13 and purchased a replacement bolt from Gm that has a normal head instead of the hex head mine came with. It has the same thread and was told by the parts counter that they must have changed design.
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
