Old 04-27-2015, 08:31 PM   #1
Niceun
Niceun's Avatar
Drives: 2012 45th edition RS 2LT
Gunshot
Hey guys what's up. Just wanted to run something by you. I'm interested in introducing a gun theme on my car and thought about making the lug Nuts look like bullets somehow. Any ideas how to do it? Maybe the ends of the lugs look let the end of a shell, says 45 CAL.
Size:  36.5 KBName:  uploadfromtaptalk1430184702003.jpg
Niceun is offline   Reply With Quote
Old 04-27-2015, 08:37 PM   #2
camarozzzz
Drives: Blue
http://www.ebay.ca/sch/i.html?_from=...+nuts&_sacat=0
camarozzzz is offline   Reply With Quote
Old 04-27-2015, 08:49 PM   #3
Niceun
Niceun's Avatar
Hey thanks for the link. Those are cool but I'm looking for the other end of the bullet. The shell. Thanks again man
Old 04-27-2015, 09:13 PM   #4
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
You need to go a lot bigger than a 50 cal .
1Coopgt is offline   Reply With Quote
Old 04-28-2015, 02:22 PM   #5
Djinn
Drives: 2LT/RS
find the shell that you want to use, cut them to the length you want, fill it with gorilla glue and insert the valve stem cap into it so its level. Only problem with that is you are going to have to polish the shell all the time, the weather will tarnish them pretty quick.
Djinn is offline   Reply With Quote
Old 04-28-2015, 08:41 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Possibly 20/30mm shell if you can find them....
olblue75 is offline   Reply With Quote
Old 04-28-2015, 09:13 PM   #7
sene
Drives: 2011 Summit White 2LS
Have you seen these -
http://www.amazon.com/Bullet-Holes-M.../dp/B0014648EI
sene is offline   Reply With Quote
