Old 01-12-2022, 04:37 PM   #29
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Originally Posted by Jake17 View Post
They’re set at 31 PSI all around. The geniuses at discount tire had one set at 40 PSI and the other three set at 25-26 PSI. It was like that when they got balanced and aligned. Would the tire pressure affect the reading of the balancing and alignment?
Tire pressure can definitely affect the alignment. Tires need to be a the proper pressure BEFORE alignment. I would go back and have the alignment re-checked.
Also, some tires will tramline a lot more than others. When I had Goodyears on my Corvette, it was ridiculous how much the car would tramline.
I switched to a set of Michelin Super Sports and it doesn't tramline at all.
Spaceme1117 is offline   Reply With Quote
Old 01-12-2022, 04:48 PM   #30
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I have all season 295f 305r with minimal tram lining.
Wyzz Kydd is offline   Reply With Quote
Old 01-12-2022, 06:31 PM   #31
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I didn't have any issues and you shouldn't if the tires are within the normal height limit if you go staggered instead of square. Traction/abs doesn't know the width of the tire it only looks at the height difference if its way off.
lt1, tires, tramline
